2006 Chevy Silverado
fades47
Member - Posts: 9
Posted: November 03, 2005 at 2:29 PM / IP Logged
Hello. Has anyone installed the Eclipse AVN-5435 in a new Silverado? If so did it slide right in or did you ned to make a bracket for it? Also is the 06 wiring the same as the 05? Any help would be appreciated.
Also looking for the stereo/sppedpulse/reverse diagrams. Thanks for the help!
oddball
Copper - Posts: 53
Posted: November 05, 2005 at 3:19 AM / IP Logged
Hello Fades47,
AVN-5435 is double-DIN, we use Best kit BKGMK422. VSS is Dk GREEN / WHITE at Instrument Cluster, Behind Gauge, there are 2 same color wires, VSS is between BLACK/ White and White. Reverse signal is BCM,C5 connector(6way),light green is it
Good Luck!
fades47
Member - Posts: 9
Posted: November 05, 2005 at 6:18 AM / IP Logged
Thanks a bunch! So with that kit I shouldnt need to do any bods for a good fit?
oddball
Copper - Posts: 53
Posted: November 05, 2005 at 11:32 AM / IP Logged
Good Morning,fades47,
BKGMK422 is good fit.also BAA4B is useful,this is antenna adaptor. I am not sure your vehicle's audio eqipment from factory, but you should use interface,like Metra,Peripheral, etc...Please let me know more info of your vehicles. Good Luck !
Friday, April 24, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
