1999 Sunfire Door Locks
blankkdx
Posted: November 06, 2005 at 6:18 PM / IP Logged
Just wondering, When hooking up a remote starter how do I hook up the power door locks. I just need to tie into the current power locks that are already installed. Do I need any relays to do this or can I just tap into the existing wires? From the database it says that the wire is light blue in either kick panel. However should I use the passenger door side to assure that all doors open (ie. not just drivers door)? What type of door locking system is in this vehicle?
Thanks in advance,
Blank
boomer_106
Silver - Posts: 710
Posted: November 08, 2005 at 1:13 AM / IP Logged
As far as whether you need relays or not depends if your unit comes with onboard relays or not. At the bottom of the diagram I just posted is specific info about the doorlocks on your vehicle. Good luck
Pontiac | | Sunfire | | 1996 - 1999
Remote Starter Wiring Colors and Notes
FunctionVehicle ColorLocation
Start:YELLOW
Ignition #1:PINKIGNITION SWITCH HARNESS
Ignition #2:WHITEIGNITION SWITCH HARNESS
Ignition #3:N/A
Accessory:ORANGEIGNITION SWITCH HARNESS
Brake Light:WHITE (+)AT SWITCH ABOVE BRAKE PEDAL
Tach Signal:WHITEAT POWERTRAIN CONTROL MODULE *
Parking Lights:BROWN (+)AT HEADLIGHT SWITCH
Headlights:BLUE (LO) & PINK (HI)(+) AT HEADLIGHT SWITCH
Diesel Glow Plug:
Clutch Bypass Wire:
Notes:* 2.4L Engine Tach Wire Is WHITE At Powertrain Control Module (PCM). 2.2L Engine Tach Wire Is BLUE/WHITE At PCM. PCM On Both Located In Passenger Front Fender. ** This vehicle is equipped with GM's PASSLOCK Anti-Theft system. See Note #113 - General Moto
Alarm and Keyless Entry Wiring Colors and Notes
Constant +12 Volts:RED (2)IGNITION SWITCH HARNESS
OEM Alarm Disarm:N/AIN SCHEMATICS
OEM Horn:BLACK (-)STEERING COLUMN HARNESS
Power Lock:L BLUEEITHER KICK W/O OEM KEYLESS
Power Unlock:WHITEPANEL WITH OEM KEYLESS ****
Trunk Release:BLACK/ WHITE (+)AT OEM KEYLESS MODULE IN TRUNK
Alarm Input Wire:LT GRN/BLK & L BLUE (-)AT CONVENIENCE CENTER MODULE ***
Notes:*** Lt. GREEN/ BLACK (-) Covers Driver Door Only, L BLUE (-) Covers All Other Doors, Diode Isolation Needed Cathode (Band) Side Of Diode Faces Oem Wires. Conv. Center Module Located Behind Driver Dash To Left Of Steering Column. **** Without OEM Keyless,
Saturday, March 7, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
