Alarm Wiring Diagrans FORD FOCUS UK SPEC
Whisky
Posted: March 17, 2002 at 12:57 PM / IP Logged
I am trying to find  Wiring diagrams for 2001 UK spec ford focus diesel keyless entry alarm systems, mostly how to  find and connect  the locking / unlocking
Platinum - Posts: 12,488
Posted: March 17, 2002 at 4:54 PM / IP Logged
Hey WHISKY, I got this off a UK Ford Focus forum and please double check all these wires to make sure of circuit verification. Good Luck and this is all I could find :
Door pin colour - BLACK/ blue
Door pin location - Left kick panel or at light
Type - negative switching
Indicators - WILL POST INFO MONDAY
Indicator location - at steering column
CDL Lock - BLACK/ red or BLACK/ orange
CDL unlock - BLACK / YELLOW
CDL location - driver's kick panel at CDL module
Parking lights - orange / YELLOW
Parking lights location - at light switch
Headlight - GREEN/ red
Headlight location - at light switch
Ignition colour - GREEN/ YELLOW
Starter colour - grey/black
Heater/AC colour - yellow
Location - all at ignition barrel
Boot pin switch colour - BLACK/ white
Boot pin switch location - at boot light
Boot release colour - WHITE/ green
Boot release location - at switch at top of dash
Type - positive switching
Brake light switch - GREEN/ red
Brake location - at switch on pedal
Tachometer colour - BLACK/ green or BLACK/ orange
Tachometer location - at the coil
Driver's FRONT window UP - yellow
Driver's FRONTwindow DOWN - tan/blue
Passenger's FRONT window UP - yellow/violet
Passenger's FRONT window DOWN - WHITE/ violet
Driver's REAR window UP - yellow/blue
Driver's REAR window DOWN - WHITE/ blue
Passenger's REAR window UP - yellow
Passenger's REAR window DOWN - white
Horn - BLACK/ red
Horn location - at steering column
Speed pulse wire for navigation
Colour - WHITE/ green
Location - behind radio in separate multipin plug
Bonnet switch - There isn't one due to the locking bonnet catch
Wipers - WHITE/ green
Wipers location - at steering column
RADIO COLOURS
12v Perm - THICK ORANGE / black
GND - BLACK / YELLOW & BLACK/ green
ACC - YELLOW /GREEN
ILLUM - THIN ORANGE / black
LF speaker - WHITE/ black & grey/black
RF speaker - WHITE/ red & grey/red
LR speaker - WHITE/ purple & grey/white
RR speaker - WHITE/ grey & whatever is left !
One of the best ways through from the cabin to the engine bay is to :
1. Remove passenger kick panel strip
2. Remove passenger kick panel
3. Pull carpet back until you can see the metal wheel arch
4. Remove the front NEARSIDE wheel
5. Remove the inner arch liner from the NEARSIDE wheel
6. If you look at the metal wheel arch which is now visible, you will see a double skinned arch.
7. If you look, you will find a small 10mm round circle which is only singled skinned, if you drill through this 'hole' it will come out in the passenger footwell. Remember to use a rubber grommet to project cables, and to waterproof / rustproof after finishing.
8. This hole can be made bigger to allow large power cable access to the cabin (Such as 4 guage power cable)
Wednesday, March 18, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
