Vehicle information for 2002 Hyundai Elantra
RLMiller
Posted: December 15, 2002 at 3:50 PM / IP Logged
I would like to get remote starter/keyless entry wiring information for a 2002 Hyundai Elantra.
Thanks,
Roger
Platinum - Posts: 12,488
Posted: December 15, 2002 at 7:49 PM / IP Logged
|              12V|red                 |+  |ignition harness            |
|          STARTER|white               |+  |ignition harness            |
|         IGNITION|red                 |+  |ignition harness            |
|        ACCESSORY|red                 |+  |ignition harness            |
| SECOND ACCESSORY|yellow              |+  |ignition harness            |
|       POWER LOCK|blk/org or blue *1  |F  |white 22 pin plug in DKP    |
|     POWER UNLOCK|same wire           |   |                            |
| PARKING LIGHTS +|grn/org(L), pink (R)|   |black 14 pin plug *2        |
| PARKING LIGHTS -|blue                |   |steering column             |
|       HEADLIGHTS|white               |-  |steering column             |
|     DOOR TRIGGER|yellow              |-  |white 22 pin plug in DKP    |
| DOME SUPERVISION|use door trigger    |   |                            |
|  TRUNK/HATCH PIN|GREEN/ black         |-  |white 22 pin plug in DKP    |
|         HOOD PIN|GREEN/ black         |-  |yellow 18 pin plug *3       |
|  FCTRY ALARM ARM|                    |   |                            |
|FCTRY ALRM DISARM|                    |   |                            |
|       TACHOMETER|blue                |   |ECM *4                      |
|      SPEED SENSE|gray/orange         |   |data link connector *5      |
|       BRAKE WIRE|white               |+  |brake pedal switch          |
|     HORN TRIGGER|red                 |-  |steering column             |
|           WIPERS|green (L), pink (H) |-  |steering column             |
|  LF WINDOW UP/DN|brown - orange      |A  |drivers window switch       |
|  RF WINDOW UP/DN|green - gray        |A  |drivers kick panel          |
|  LR WINDOW UP/DN|pink - blue         |A  |drivers kick panel          |
|  RR WINDOW UP/DN|white - brown       |A  |drivers kick panel          |
| SUN RF OPN/CLOSE|yellow - yel/red    |A  |sun roof motor              |
|        RADIO 12V|red                 |+  |radio                       |
|     RADIO GROUND|black               |-  |radio                       |
|     RADIO SWITCH|yellow              |+  |radio                       |
| RADIO ILLUMINATE|pink                |+  |radio                       |
|    POWER ANTENNA|gray/orange         |+  |radio                       |
|       LF SPEAKER|white - brown       |   |radio                       |
|       RF SPEAKER|green - orange      |   |radio                       |
|       LR SPEAKER|yellow - black      |   |radio                       |
|       RR SPEAKER|orange - blue       |   |radio                       |
Notes:
NOTE: Some models have an immobilizer system that needs to be bypassed during remote start.  *1 These wires are only in vehicles with keyless entry. The blk/org wire will test when when moving the driver lock knob, the blue wire will test when moving the passenger lock knob. Vehicles without keyless entry need to add an actuator in the driver door.  *2 The plug is on the front of the fuse box below the fuses.  *3 The plug is behind the fuse box.  *4 The ECM is above the driver kick panel, the tach wire is in pin 66.  Can also find tach at the ignition coils on the driver side of the engine, use either the yellow or green wire.  *5 The data link connector is under the driver side dash under the steering column.
Tuesday, March 3, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
