2005 chevy 2500hd remote start
dlambe
Copper - Posts: 57
Posted: December 06, 2005 at 11:50 PM / IP Logged
ok guys i am trying to install a viper 130xv remote starter into a 2005 chev 2500hd, I have never seen such a mess  of wiring for a remote starter, can someone please post a straight forward wiring schematic for me to install the bloody thing. I also need to install the passlock 2 override with it (another viper module, by the way I think that these things are total crap), the tech support for these is such b.s, they dont help you at all. I appreciate the help and please email or pm me when you post this thx.
1ts2345y
Posted: December 07, 2005 at 6:22 PM / IP Logged
12+ red ,  ign pink,  2ign white,  starter yellow,  acc  orange,  2acc brown   all positve.     brake  white at brake switch.  horn black yellow neg  parking lights gray black neg. tach is white at instrment cluster.  i use astro flex for the passlock and doorlocks iom-gmc 3  or  gmdl-bp form bypass kit  very simple
1994honda2005
Member - Posts: 11
Posted: December 07, 2005 at 9:08 PM / IP Logged
12volts      red (40A), red (40A)       +       ignition harness
Starter      yellow       +       ignition harness
Second Starter      N/A
Ignition      pink       +       ignition harness
Second Ignition      white       +       ignition harness
Notes: To avoid the check engine light from coming on and possible damage to the automatic transmission, the second ignition in this vehicle MUST be powered when adding a remote start system.
Third Ignition      N/A
Accessory      orange       +       ignition harness
Second Accessory      brown       +       ignition harness
Keysense      lt. green       -       ignition harness
Power Lock      use 457G or 456G module
Notes: If Directed module 457G or 456G is not available, refer to DirectFax document 1601.
On base model trucks, the 457G or 456G is not necessary. Instead, the lock wire is lt. blue (-), pin B5, and the unlock wire is white (-), pin B10. They are in the lt. blue plug at the BCM.
Power Unlock      see power lock
Lock Motor      gray       5wi      driver door module in door
Unlock Motor      tan       5wi      driver door module in door
Parking Lights+      brown       +       driver kick panel
Parking Lights-      gray/black       -       switch or BCM, brown plug, pin B2
Notes: The BCM (Body Control Module) is under the driver side dash. It has 6 plugs in it, the purple plug is on the back.
Hazards      white       -       hazard switch
Turn Signal(L)      dk. green       +       turn signal switch
Turn Signal(R)      lt. green       +       turn signal switch
Reverse Light      lt. green       +       BCM, black plug, pin F
Door Trigger      gray/blk (L), BLACK/ wht (R)       -       each door module in each door
Notes: On base model trucks, the door trigger wires are in the lt. blue plug at the BCM, pins B4 and A5.
On 4dr trucks, the LR door trigger is lt. blue/black, pin A3, and the RR is lt. GREEN/ black, pin A2. They are in the purple plug at the BCM.
Use all wires and diode isolate.
Dome Supervision      gray/black       +       BCM, black plug, pin E
Trunk/Hatch Pin      N/A
Hood Pin      N/A
Trunk/Hatch Release      N/A
Power Sliding Door      N/A
Factory Alarm Arm      arms on lock with door open
Factory Alarm Disarm      lt. green       -       driver door module in door
Disarm No Unlock      see factory alarm disarm
Tachometer      white       ac       instrument cluster, pin A5 or PCM
Notes: The PCM (Powertrain Control Module) is in the left front of the engine compartment to the left of the fan shroud.
On gas models, the tach wire is in the green plug, pin 10.
On diesel models, the tach wire is in the gray plug, pin 37.
On hybrid models, the tach wire is in the green plug, pin 35.
For tach can also go to any of the ignition coils or fuel injectors and use the wire that is NOT pink, black, or brown.
Wait to start      dk. blue       -       instrument cluster, pin A2 or PCM
Notes: The PCM (Powertrain Control Module) is in the left front of the engine compartment to the left of the fan shroud. The wait to start wire is in the blue plug, pin 26.
Brake Wire      white       +       brake pedal switch
Parking Brake      lt. blue       -       switch or BCM, lt. blu plug, pin A7
Horn Trigger      BLACK / YELLOW to black       -       switch or BCM, gray plug, pin B9
Memory Seat 1      red       +       driver door module in door
Memory Seat 2      pink       +       driver door module in door
Memory Seat 3      N/A       +
Interface Module:      Category:
Immobilizer Bypass      Required:
Yes      Type:
Passlock II
Part #: 556LW
Alternate Part1 #: 555LW
Alternate Part2 #: 555T
Alternate Part3 #: DesignTech 20402
Alternate Part4 #: DesignTech 29402
Notes: Not required if using the combo interface module.
The Passlock II wire colors are yellow, black, and RED / white (not used).
Door Lock Interface      Required:
Yes      Type:
Data Bus
Part #: 456G
Combo Interface      Required:
Yes      Type:
Data Bus
Part #: 457GW
Notes:
