2005 Dodge Ram Crew Cab Alarm/RS Wiring
jvorrius
Member - Posts: 12
Posted: December 13, 2005 at 4:42 PM / IP Logged
Hi,
Need to know if anyone has a wiring diagram for a 2005 Dodge Ram 1500 Crew Cab (hemi).
The truck only has keyless entry now. No Alarm
Going to hook up a Valet 561R remote start this weekend. If anyone could help that would be great!
James
Mike M2
Platinum - Posts: 2,652
Posted: December 14, 2005 at 6:53 AM / IP Logged
12volts
red (40A), red (40A)
ignition harness
Starteryellow + ignition harness
Second StarterN/A
Ignitionpink/white + ignition harness
Second Ignitionpink/lt. green + ignition harness
Third Ignitionpink / YELLOW (10 AWG)(3rd acc) + ignition harness
Accessorydk. blue and pink/yel (16 AWG) + ignition harness
Second Accessorypink / YELLOW (14 AWG) + ignition harness
KeysensePURPLE / tan - ignition harness
Power LockPURPLE / dk. green - driver kick, door harness
Power Unlocksame as power lock wire
Lock Motorlt. green 5widriver kick, door harness
Unlock Motortan/lt. green 5widriver kick, door harness
Parking Lights+WHITE/ yel (L), WHITE/ gray (R) + harness at top of driver fender
Parking Lights-WHITE/ lt. green - headlight switch
HazardsWHITE/ orange - hazard switch
Turn Signal(L)use hazards wire
Turn Signal(R)use hazards wire
Reverse LightWHITE/ lt. green + inside mirror or plug by PCM
Door Triggersee notes - see notes
Dome Supervisionyellow/lt. blue or yellow/org + driver A pillar or cluster
Trunk/Hatch PinN/A
Hood PinN/A
Trunk/Hatch ReleaseN/A
Power Sliding DoorN/A
Factory Alarm ArmPURPLE / lt. blue - driver kick, door harness
Factory Alarm Disarmsame as factory alarm arm wire
Disarm No Unlocksee factory alarm disarm
Tachometerdk. blue/gray ac PCM, orange plug, pin 34
Wait to startsee DirectFax document 1091
Brake WireWHITE/ tan + brake pedal switch
Parking Brakedk. GREEN / WHITE - parking brake switch
Horn Triggerdk. GREEN/ purple - horn switch
Mike M2
Tech Manager
CS Dealer Services
jvorrius
Member - Posts: 12
Posted: December 14, 2005 at 10:31 AM / IP Logged
Thank you Mike!
James
Monday, March 16, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
