2005 Mazda 3s wiring diagram, alarm start
jnye6625
Member - Posts: 22
Posted: December 17, 2005 at 11:57 PM / IP Logged
Can someone please help me out with this.  I need a wiring diagram for a 2005 mazda 3s.  Thanks
infinkc
Copper - Posts: 438
Posted: December 18, 2005 at 11:56 AM / IP Logged
WIRING INFORMATION - MAZDA / 3 / 2005 / Remote Start
12volts red (30A), BLACK/ red (30A)   +   ignition harness
Starter gray/black   +   ignition harness
Second Starter N/A
Ignition GREEN/ YELLOW   +   ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory pink / YELLOW   +   ignition harness
Second Accessory yellow   +   ignition harness
Keysense RED / black   +   ignition harness
Power Lock GREEN/ red   -   driver kick, door harness
Notes: Lock is negative trigger thru an 1,000 ohm resistor. Unlock is a straight negative trigger. MUST use relays.
Power Unlock same as power lock wire
Lock Motor yellow/black   5wi driver kick, door harness
Unlock Motor WHITE/ black   5wi driver kick, door harness
Parking Lights+ ORANGE / white (L), orange (R)   +   passenger kick, harness to rear
Parking Lights- BLACK/ white   -   headlight switch
Hazards BLACK/ orange   -   hazard switch
Turn Signal(L) blue   +   passenger kick, harness to rear
Turn Signal(R) blue/red   +   passenger kick, harness to rear
Reverse Light GREEN/ orange or GREEN/ black   +   passenger kick, harness to rear
Door Trigger see notes   -   passenger kick, harness to rear
Notes: The LF door is BLACK / YELLOW, the RF door is BLACK/ blue, the LR door is BLACK/ orange, and the RR door is BLACK/ green. Use all four wires and diode isolate each. These wires are also found at the Passenger Junction Box behind the glove box.
These wires may rest at ground with the doors closed and go to an open circuit when the doors are opened.
Dome Supervision BLACK/ blue to BLACK/ red   -   passenger kick, harness to rear
Trunk/Hatch Pin BLACK/ red or BLACK/ blue   -   passenger kick or light in trunk
Hood Pin BLACK / YELLOW   -   hood pin switch
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm BLACK/ blue   -   driver kick, door harness
Notes: This wire may also lock the doors.
Factory Alarm Disarm BLACK/ white   -   driver kick, door harness
Notes: This wire may also unlock the doors.
Disarm No Unlock
Tachometer NOT GREEN/ stripe   ac   any ignition coil or fuel injector
Wait to start N/A
Brake Wire RED / white   +   brake pedal switch
Parking Brake BLACK/ lt. green   -   parking brake switch
Horn Trigger black   -   horn switch
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Interface Module: Category:
Immobilizer Bypass Required:
Yes Type:
Transponder
Part #: 556UW
Alternate Part1 #: 555U
Alternate Part2 #: DesignTech 20402
Alternate Part3 #: DesignTech 29402
Notes:
Door Lock Interface Required:
Yes Type:
Multiplex
Part #: 456LW
There are 10 types of people in the world, ones that understand binary and ones that dont.
jnye6625
Member - Posts: 22
Posted: December 22, 2005 at 4:43 PM / IP Logged
Thank you very much for the info!
