Mazda Protege 2003
marcoux321
Member - Posts: 9
Posted: January 24, 2006 at 7:17 AM / IP Logged
Hello,  I installed a remote starter on my mazda protege 2003 with your information.  And you said, the tach wire is the PURPLE / white, but he does'nt.  when you turn the key,  you have power on this wire, even if you don't star the car.
I need a tach wire to say at my remote starter computer, if my car run or not.  But the PURPLE / white wire does'nt say that.
Do you know which wire instead of the PURPLE / white to make that and where is he?
KarTuneMan
Platinum - Posts: 7,056
Posted: January 24, 2006 at 8:35 AM / IP Logged
PURPLE / white behind the guage cluster or same color at the test connector under hood. drivers side firewall gray "box"
marcoux321
Member - Posts: 9
Posted: January 24, 2006 at 10:27 AM / IP Logged
I knew this wire, but like I said, even if the engine can't start when you try to start it with the remote, you get 12v on this wire.
If you but the key on ON, you get power on this wire.  Why do you call this wire a tach wire?  Maybe I did something wrong but I don't think so really.
Please help me.
Fred
