2003 toyota matrix remote starter
impala_man2003
Member - Posts: 34
Posted: March 04, 2006 at 5:45 PM / IP Logged
all i want to do is install the remote start feature not the alarm what wires do i need to use and can someone tell me where to find the fuse box
L67 Master (GM 3.8 SC)
KarTuneMan
Platinum - Posts: 7,056
Posted: March 04, 2006 at 6:00 PM / IP Logged
impala_man2003
Member - Posts: 34
Posted: March 04, 2006 at 6:21 PM / IP Logged
can some one tell me what wire i will need to use form the 24 pin wire harness all i want tis the remote start feature
impala_man2003
Member - Posts: 34
Posted: March 04, 2006 at 7:20 PM / IP Logged
i have connected all the main wires but the car in still not turing over i am only using the remote start function. not the alarm i think that i am supopsed to use some one the 24 pin wires in that harrness what are the main ones that i need to use for the install. i have used the brake wire, the sys ground and the tach output whic other wires should i use just for the remote start function.
Monday, January 5, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
