Need Wiring Diagram
kingss
Posted: January 02, 2003 at 1:31 PM / IP Logged
Need Wiring Diagram For 1994 Dodge Grand Caravan  so I can install alarm
do i need any special relay other then the one that came with the alarm it a autopage RS750 lcd
Platinum - Posts: 12,488
Posted: January 02, 2003 at 11:14 PM / IP Logged
|              12V|red & pink/black    |+  |ignition harness            |
|          STARTER|yellow              |+  |ignition harness            |
|         IGNITION|dk. blue            |+  |ignition harness            |
|        ACCESSORY|BLACK/ orange        |+  |ignition harness            |
|       POWER LOCK|ORANGE / white        |+  |relays in center console    |
|     POWER UNLOCK|pink/purple         |+  |relays in center console    |
|       LOCK MOTOR|ORANGE / black        |   |keyless entry module *1     |
|     UNLOCK MOTOR|dk. blue            |   |keyless entry module *1     |
|    DISARM DEFEAT|pink/purple         |   |keyless entry module *1     |
| PARKING LIGHTS +|BLACK / YELLOW        |   |low in drivers kick         |
| PARKING LIGHTS -|BROWN / orange        |   |headlight switch            |
|       HEADLIGHTS|ORANGE / white        |-  |headlight switch            |
|     DOOR TRIGGER|yellow              |-  |center console *2           |
| DOME SUPERVISION|use door trigger    |   |                            |
|  TRUNK/HATCH PIN|tied in with doors  |   |                            |
|TRNK/HTCH RELEASE|GREEN/ black         |+  |at switch                   |
|       TACHOMETER|blk/gry,red,blu/yel |   |coil pack *3                |
|       BRAKE WIRE|WHITE/ tan           |+  |brake pedal switch          |
|     HORN TRIGGER|BLACK/ red           |-  |steering column             |
|           WIPERS|RED / yellow          |+  |steering column             |
|  LF WINDOW UP/DN|lt. blue - white    |A  |drivers door switch         |
|  RF WINDOW UP/DN|brn/wht - pur/wht   |A  |drivers door or kick        |
|  LR WINDOW UP/DN|lt. blue - white    |A  |LR window switch            |
|  RR WINDOW UP/DN|brn/wht - pur/wht   |A  |RR window switch            |
Notes:
*1 The keyless entry module is located under the top of the dash panel in the center of the dash.    *2 Look for the silver module bolted to the floor close to the door lock relays behind the center console.  *3 The 3.3L V6 engine uses a triple coil pack. Wire colors are for 2 cylinders each. For 3.0L V6 and 2.5L 4 cyl engines use gray at the coil.
Tuesday, March 3, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
