2002 745i Adding a Sub Amp
billfitz
Posted: January 12, 2003 at 11:24 AM / IP Logged
I am working on a 2002 BMW 745i adding a sub amp and subs to the factory system.
I am looking for a full-range non-filtered, non-crossed-over signal source to feed the sub amp for optimal music.  I have located signal source from the amp in the rear trunk, but it seems to be filtered or crossed over.
This is a Becker Logic 7 system with one Becker amp located behind the driver rear wheel well in the trunk.  The connector on the amp has a ground, +12V, Rear Left Speaker +/-, Rear Right Speaker +/-, an unbalanced front speaker +/-, and two other pairs which are 5V but don't seem to have any signal on them (not sure what these are yet).
Thanks!
Moderator - Posts: 12,488
Posted: January 12, 2003 at 12:12 PM / IP Logged
You will have to grab the speaker outputs from the back of the deck to get a non crossed over signal to the sub amp or use the input sires into the OEM amp. Run new wires from the back of the deck/amp to the amplifier ( if it has high level inputs ) and if not use a LOC.
Wednesday, November 26, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
