03 BMW 325 Radio
tech410r
Member - Posts: 12
Posted: August 11, 2006 at 7:33 PM / IP Logged
I need some info on installing as aftermarket radio in a '03 BMW 325. A wiring guide would help also, thanks!
Hornshockey
Silver - Posts: 520
Posted: August 12, 2006 at 1:05 AM / IP Logged
If I remember correctly pulling the factory radio out is no biggie, carefully pry the wood panel off from around the top & sides of the radio, then 2 torx screws on the sides of the radio.  Metra dash kit 99-9300
Does it have the upgraded sound system?  If not, then you can use metra's 70-9003 to wire behind the radio (you may be able to use that one even on the upgraded system)  Use a euro antenna adaptor and you're all set!  Just be prepared for some fun times fitting all those wires behind the radio, it's pretty tight back there!
Life moves pretty fast; if you don't stop and look around once in a while; you could miss it.
Monday, April 27, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
