1983 VW Polo Mk2 stereo wiring diagram
wildchilduk
Posted: August 15, 2006 at 6:20 AM / IP Logged
I have a 1983 Volkswagen Polo Mark 2, i need a wiring diagram showing me which wires are ground/constant/illum e.t.c
If this helps i have a picture of the only 4 wires for the stereo: (the one which looks orange is actually brown).
1983 VW Polo Mk2 stereo wiring diagram -- posted image.
djfearny2
Silver - Posts: 810
Posted: August 15, 2006 at 6:55 AM / IP Logged
with that car all you need is a simple test light that will determine which wire has power all the time., ground could just be a good piece of metal. you dont really need illumination. the two main wires are constant 12 volts which means the test light lit up at all times. and switched 12 volts. which means test light turns on and off when you turn the key on and off. a test light you need is less than 5 bucks and can be gotten anywhere autoparts are sold or your local wallmart. hope this helps.
Jon
Installer/Help Technician
---coral springs florida---
