1995 Acura Integra Brake pedal switch & h
t0mmyr
Copper - Posts: 55
Posted: September 03, 2006 at 7:22 PM / IP Logged
I've been trying to install a new 791xv all day in my friends integra, everything is almost done, i tested it and remote start works great everythings working great...but i'm having the hardest difficulty finding the positive brake wire and the horn trigger, it says GREEN / WHITE wire above the pedal but i cant get to the wire, i can almost see a blue plug behind a black loom of cable but i can't get to it. does anyone know if theres an alternate location or alternate wire to get for the brake wire, perhaps a wire going into the fuse box under the steering wheel
i also cant find the horn trigger wire, i probed nearly all the wires i could find on the steering wheel and none went up or down when i pushed the horn, i cant find the gray or blue/green wire, is there a special panel beside all the plastc to remove?
KarTuneMan
Platinum - Posts: 7,056
Posted: September 03, 2006 at 7:31 PM / IP Logged
Brakes. grn/wht in drivers kick POS(+)
Horn. look at the inside 10mm bolt holding the fuse box....up and to the right there is a plug with 4  wires in it, the plug is white. find the lt.blue/grn NEG(-) horn wire.
t0mmyr
Copper - Posts: 55
Posted: September 03, 2006 at 7:46 PM / IP Logged
just got back from kick, tested 3 green wires on lowest bottom loom, 2 small awg 1 fat one, but none of them +12 when i pressed the brake wire...is this the right loom?
KarTuneMan
Posted: September 04, 2006 at 12:50 PM / IP Logged
it's up high...look for a big brown plug bolted with a 10mm. kinda behind that, and up!
integratyper934
Copper - Posts: 150
Posted: September 21, 2006 at 9:36 PM / IP Logged
i got it on my car no problem.....disconnect the plug at the switch to get extra slack or just go to the kick and get the wire there.....
Sunday, February 8, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
