1998 Mits. Eclipse fuse panel
willie69
Member - Posts: 12
Posted: October 15, 2006 at 2:39 PM / IP Logged
I was wondering if anyone had a diagram of this they could post or PM me please?!
KarTuneMan
Platinum - Posts: 7,056
Posted: October 15, 2006 at 5:08 PM / IP Logged
 MODEL YEAR(S)
 ECLIPSE  1995 -1999
 KEY T-HARNESS IMMOBILIZER
  N/A   N/A   N/A
 PART  COLOR LOCATION
 12 VOLT CONSTANT  WHITE (+)   IGNITION SWITCH HARNESS
 STARTER BLACK/ RED (+)  IGNITION SWITCH HARNESS
 STARTER 2 N/A
 IGNITION 1 BLACK/ WHITE (+) IGNITION SWITCH HARNESS
 IGNITION 2 N/A
 IGNITION 3 N/A
 ACCESSORY /HEATER BLOWER 1 BLUE/BLACK (+)  IGNITION SWITCH HARNESS
 ACCESSORY /HEATER BLOWER 2 N/A
 KEYSENSE N/A
 PARKING LIGHTS ( - ) GREEN / WHITE (-)  @ HEADLIGHT SWITCH, GRAY 20-PIN PLUG
 PARKING LIGHTS ( + ) GREEN / WHITE (+)  IN DRIVERS KICK PANEL, HARNESS to REAR of VEHICLE
 POWER LOCK BROWN / WHITE (TYPE B)  IN DRIVERS KICK PANEL, HARNESS TO REAR OF VEHICLE
 POWER UNLOCK BROWN (TYPE B)  IN DRIVERS KICK PANEL, HARNESS TO REAR OF VEHICLE
 DOOR TRIGGER RED / GREEN (-) See NOTE *1  IN DRIVERS KICK PANEL, HARNESS to REAR of VEHICLE.
 DOMELIGHT SUPERVISION USE DOOR TRIGGER, Requires Part #775 Relay
 TRUNK RELEASE N/A
 SLIDING POWER DOOR N/A
 HORN GREEN/ BLACK (-)  @ STEERING COLUMN HARNESS
 TACH WHITE  @ INSTRUMENT CLUSTER or PCM, See NOTE *2
 WAIT TO START LIGHT N/A
 BRAKE GREEN / WHITE (+)  @ SWITCH ABOVE BRAKE PEDAL
 FACTORY ALARM DISARM  GREEN / WHITE (-)  IN DRIVERS KICK PANEL, IN DRIVERS DOOR HARNESS
 ANTI-THEFT N/A
 EXTRA INFORMATION
 NOTE *1 CAN ALSO USE RED / WHITE (-) AT INSTRUMENT CLUSTER. RED / WHITE (-) ALSO CATCHES THE REAR HATCH. NOTE *2 THE PCM (Powertrain Control Module) IS LOCATED ON THE DRIVERS SIDE OF ENGINE COMPARTMENT OR BEHIND THE CENTER OF THE DASH.
willie69
Member - Posts: 12
Posted: October 15, 2006 at 5:37 PM / IP Logged
thanks so much for that as it is also something I was needing. But, I was looking for the layout of the fuses and their wattage(?) for the box at the bottom of the steering column.
thanx though!
Friday, February 27, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
