2007 Saturn Sky Alarm/Remote Start Wiring
nargauzius
Posted: October 17, 2006 at 7:04 PM / IP Logged
Hello,
Looking for wiring diagrams for the 2007 Saturn Sky. Having an intermittent "no-start" problem that I suspect to be a damaged/faulty wire, but don't want to misconnect my multi-meter without knowing what's what on the BCM and ECM. Had an aftermarket alarm installed by a company I wish I hadn't gotten such good recommendations for, and not getting the right help from the right people. I'm sure I can figure this out without having to de-install everything so long as I know what I'm looking at.
Diagnostics for these modules are down to the mA and some you can't connect to when they're powered, so I don't want to screw up.
Thanks!
Mike M2
Platinum - Posts: 2,652
Posted: October 19, 2006 at 3:42 PM / IP Logged
12voltsRED / black (50A) + BCM, C3, pin D1
Notes: The BCM (Body Control Module) is part of the fuse/relay box below the glove box. It has the following connectors: C1-72 pin gray plug, C2-72 pin gray plug, C3-41 pin red plug, and C4-68 pin lt. gray plug.
Starteryellow (not for remote start) - ECM, gray 56 pin plug, pin 56
Notes: The ECM (Engine Control Module) is in the driver side rear corner of the engine compartment.
There is a white wire and a WHITE/ black wire in the ignition harness, or the BCM, C2, pins 56 and 62, that perform starter, second ignition, and key sense functions. No information at this time, if it is necessary to interface with these wires in addition to the PASS-key III+.
Second StarterN/A
Ignitionyellow + ign harn or BCM, C4, pin D3
Second Ignitionsee starter wire notes
Third IgnitionN/A
Accessorybrown + ign harn or BCM, C4, pin C8
Second AccessoryN/A
Keysensesee starter wire notes
Power Lockuse the motor wires
Power Unlockuse the motor wires
Lock Motorgray 5widriver kick or BCM, C3, pin A4 or A5
Unlock Motortan 5widriver kick or BCM, C3, pin B1
Parking Lights+brown + driver kick or BCM, C3, pin A7
Parking Lights-BROWN / white - switch or BCM, C2, pin 5
Hazardswhite - switch or BCM, C2, pin 9
Turn Signal(L)lt. blue (F), yellow (R) + BCM, C1, pin 35 and C3, pin A9
Turn Signal(R)dk. blue (F), dk. green (R) + BCM, C1, pin 17 and C3, pin A12
Reverse Lightlt. green + kick panel, harness to rear
Door Triggergray/black (D), tan/white (P) - each kick or BCM, C1, pins 22 and 19
Notes: Use both wires and diode isolate each.
Dome Supervisiongray - BCM, C3, pin A10
Trunk/Hatch PinORANGE / black - BCM, C1, pin 55
Hood PinN/A
Trunk/Hatch Releasetan - switch or BCM, C2, pin 10
Power Sliding DoorN/A
Factory Alarm Armfactory remote only
Factory Alarm Disarmfactory remote only
Disarm No Unlockwith ignition and Passkey
TachometerNOT pink/black or pink ac any fuel injector
Wait to startN/A
Brake Wirelt. blue + passenger kick or BCM, C1, pin 53
Parking Brakelt. blue - switch or BCM, C1, pin 14
Horn Triggertan - switch or BCM, C2, pin 14
Memory Seat 1N/A
Memory Seat 2N/A
Memory Seat 3N/A
2007 Saturn Sky Alarm/Remote Start Wiring -- posted image.
Interface Module:Category:
Immobilizer Bypass
Required:
Yes
Type:
PASS-Key III+
Part #: 556UW
Alternate Part1 #: DesignTech 20402
Alternate Part2 #: DesignTech 29402
Notes: Standard on all models.
Mike M2
Tech Manager
CS Dealer Services
