01 Dodge Ram Diesel remote start diagram
martinezrp
Member - Posts: 6
Posted: November 07, 2006 at 9:28 PM / IP Logged
Does someone have a remote start wiring diagram  for a 2001 Dodge Ram Diesel?
Platinum - Posts: 12,488
Posted: November 07, 2006 at 11:28 PM / IP Logged
Dodge | | Ram Pickup | | 1999 - 2001
Remote Starter Wiring Colors and Notes
FunctionVehicle ColorLocation
Start:BLUE / YELLOW
Ignition #1:D BLUEIGNITION SWITCH HARNESS
Ignition #2:BLACK/ ORANGEIGNITION SWITCH HARNESS (HEAT/AC)
Ignition #3:N/A
Accessory:BLACK/ WHITEIGNITION SWITCH HARNESS
Brake Light:WHITE/ TAN (+)AT SWITCH ABOVE BRAKE PEDAL
Tach Signal:GRAY/L BLUEAT POWERTRAIN CONTROL MODULE **
Parking Lights:BLACK / YELLOW (+)AT HEADLIGHT SWITCH ****
Headlights:LT. GREEN (+)AT HEADLIGHT SWITCH
Diesel Glow Plug:ORANGE / BLACKIN LARGE CONN. UNDER LEFT SIDE DR. DASH
Clutch Bypass Wire:
Notes:* 2000 Vehicles may be equipped with a transponder immobilizer system. See Installation Note #144 - Bypassing Transponder Theft Systems. ** Powertrain Control Module Located On Passenger Rear Of Engine On Firewall.
Alarm and Keyless Entry Wiring Colors and Notes
Constant +12 Volts:PINK/BLACK & REDIGNITION SWITCH HARNESS
OEM Alarm Disarm:LT. GREEN/ ORANGE (-)# PIN CONN. BEHIND DRIVER'S DASH *****
OEM Horn:BLACK/ RED (-)STEERING COLUMN HARNESS
Power Lock:ORANGE / VIOLETBLACK 8 PIN CONNECTOR
Power Unlock:PINK/VIOLETIN DRIVER'S KICK PANEL ***
Trunk Release:N/A
Alarm Input Wire:YELLOW (-)AT HEADLIGHT SWITCH **
Notes:** YELLOW (-) Wire Also Located In 8 Pin Black Connector Above Passenger Kick Panel. *** See Note Installation Note # 203 - Reverse Polarity Diagram For Unlock. See Note Installation Note # 202 - Positive Polarity Diagram For Lock. **** This Wire Can Be
