Wiring for a 96 GMC Yukon
kevin2254
Posted: November 09, 2006 at 9:29 AM / IP Logged
Used a wiring harness but the rear door speakers aren't working, i heard that they run off a separate amp needed to see if there are any suggestions.
kevin fosbenner
jason quarters
Member - Posts: 18
Posted: November 18, 2006 at 6:12 PM / IP Logged
there is a small  amp for those speakers under diver dash by gas pedal.  wires are light blue/dark blue  whitch are right rear, cut them and wire them to the red and white wires that are there.  the other two are the left side.  hope this helps
its true!
kevin2254
Posted: December 05, 2006 at 7:45 AM / IP Logged
thanks, i will try that today
kevin fosbenner
