01 Ford Explorer Sport Trac
Welcome Guest :)
altbs
Member -
Posted: November 10, 2006 at 8:27 PM / IP Logged
Need to put remote start in a 2001 Ford Explorer SportTrac if anyone has a wiring diagram I would appreciate it.
KarTuneMan
Platinum -
Posted: November 14, 2006 at 5:10 PM / IP Logged
| Wire/Function | Colour | Location/Description | Polarity |
| PASSIVE ANTI-THEFT | YES | TRANSPONDER | SEE NOTES |
| 12 VOLTS | Yellow | Ignition switch harness | + |
| IGNITION | Lt.GREEN/ violet | Ignition switch harness | + |
| IGNITION 2 | BLACK/ green | Ignition switch harness | + |
| ACCESSORY | Brown | Ignition switch harness | + |
| STARTER | Red & RED / blue | Ignition switch harness | + |
| KEY SENSE | BLACK/ pink | Ignition switch harness | - |
| | | Wire goes to pin 10 (early production) or pin A-18 (late production) of GEM behind center of dash. |
| TACH SIGNAL | See notes | At coil pack on engine | AC |
| | | This is a multi-coil engine. On the 4L the wire is TAN/WHITE and on the 5L it is RED / BLUE. Set your remote starter for 2 cylinders. |
| LOCK | Pink / YELLOW | In driver's kickpanel | - |
| | | The locks stop working 20 seconds after the doors are locked. To unlock the doors, you must pulse the disarm wire (GREEN/ VIOLET) at the same time as unlock. For models equipped with no keyless entry or security, the doorlock are reverse polarity. |
| UNLOCK | Pink/green | In driver's kickpanel | - |
| DRIVER LOCK MOTOR | Pink/black | In driver's kickpanel | + |
| DRIVER UNLOCK MOTOR | RED / orange | In driver's kickpanel | + |
| PASSENGER UNLOCK MOTOR | Pink/orange | In passenger side kickpanel | + |
| DOORPIN | BLACK/ blue | In driver's kickpanel | + |
| FACTORY DISARM | GREEN/ purple | In driver's kickpanel | - |
| BRAKESWITCH | RED / green | At switch above brake pedal | + |
| PARKLIGHTS | Brown | At steering column | + |
| HORN | YELLOW /GREEN | At steering column | - |
| HEADLIGHTS | RED / yellow | At steering column | + |
| VSS WIRE | Gray/black | Behind instrument panel | AC |
Friday, May 1, 2026
• Copyright © 1999-2026 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
