2001 Ford Taurus SES Stereo Wiring
kpedx
Posted: November 12, 2006 at 3:35 PM / IP Logged
need a stereo wiring diagram for a 2001 ford taurus ses, the diagram i found here doesnt match up with my wires
KarTuneMan
Platinum - Posts: 7,056
Posted: November 12, 2006 at 11:49 PM / IP Logged
+12V DC Battery(Constant)RED / yellow Control unit in left side of luggage compartment 117 20 amp Junction box in front center of engine compt.
Switched AccessoryRED / orange In-line with the starter relay 127 5 amp Junction box in front center of engine compt.
Ground BLACK/ lt.green
Power Antenna RED / pink
Remote Turn On(output) BROWN / orange Pin 8 of CD changer. Also light GREEN/ black between rear control unit (C388B-2) and front panel (pin 4).
Left Front + ORANGE / lt.green
Left Front - Lt.blue/white
Right Front + WHITE/ lt.green
Right Front - Dk.GREEN/ orange
Left Rear + Grey/lt.blue
Left Rear - Tan / YELLOW
Right Rear + ORANGE / red
Right Rear - BROWN / pink
2001 Ford Taurus SES Stereo Wiring -- posted image. AT SPEAKERS
Wire FunctionColorNote
Left Front Tweeter + ORANGE / lt.green If equipped
Left Front Tweeter - Lt.blue/white If equipped
Right Front Tweeter + WHITE/ lt.green If equipped
Right Front Tweeter - Dk.GREEN/ orange If equipped
2001 Ford Taurus SES Stereo Wiring -- posted image.  Available Notes
Notes
Information listed in the harness section refers (in this case) to the rear control unit in left side of the luggage compartment.
INTEGRATED CONTROL PANEL has WHITE/ red for battery input (pin 11), with fuse no. 216 of 15 amps, BLACK/ pink for acc. power (pin 6), with fuse no. 211 of 15 amps, RED / yellow for hot in start or run (pin 16), with fuse no. 227 of 10 amps; these fuses are in the central junction box.
AUDIO connections between the integrated control panel (front) and the rear control unit (rear) are as follows:
R+ dark blue/white wire between pin 9 front & pin C388B-7 rear
R- gray wire between pin 19 front & pin C388B-20 rear
L+ BROWN / light green wire between pin 20 front & pin C388B-6 rear
L- WHITE/ pink wire between pin 10 front & pin C388B-19 rear
kpedx
Posted: November 13, 2006 at 2:48 AM / IP Logged
thanks a bunch man, and if you dont mind me asking, were did you find this?
