2006 Chevy Equinox VSS
drvnbysound
Silver - Posts: 289
Posted: November 27, 2006 at 3:31 AM / IP Logged
Anyone have this information? Installing AVIC-D2 soon. Thanks! in advance.
KarTuneMan
Platinum - Posts: 7,056
Posted: November 27, 2006 at 9:34 AM / IP Logged
REVERSE LIGHTS Lt.green Low in driver's kickpanel   +
 VSS WIRE Brown Pin-22 of Blue plug on PCM   8000ppm
 The PCM is located under the hood near the pass. Side strut tower below the air duct.
 DATABUS INTERFACE Pin-2(top row from left) Diagnostic plug below dash   DATA
 PASSLOCK DATA Yellow In 3 wire harness from ignition switch   DATA
 PASSLOCK GROUND ORANGE / black In 3 wire harness from ignition switch   -
sparkie
Platinum - Posts: 2,061
Posted: November 27, 2006 at 12:44 PM / IP Logged
The brown wire in cavity 4 of the throttle actuator is the VSS wire. It is on the passenger side of the motor at the top rear corner. It is easy to see.
sparky
drvnbysound
Silver - Posts: 289
Posted: November 27, 2006 at 12:51 PM / IP Logged
Thanks! to both of you for the information.
The customer will greatly appreciate the added accuracy of their navigation system due to this knowledge 2006 Chevy Equinox VSS -- posted image.
Saturday, February 28, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
