2007 Ford Fusion
cashmoney
Member - Posts: 17
Posted: December 01, 2006 at 10:22 AM / IP Logged
Looking to install  a remote start on an 07 fusion. Does anyone have the wiring diagram for this vehicle and also what type of bypass kit will it need? Prefer Dei.
cashmoney
KarTuneMan
Platinum - Posts: 7,056
Posted: December 09, 2006 at 11:01 PM / IP Logged
DEI sucks...
Wire/Function Colour Location/Description Polarity
 PASSIVE ANTI-THEFT YES TRANSPONDER   SEE NOTES
 This vehicle is equipped with TRANSPONDER chips in the ignition keys. This system must be bypassed for Remote Starter installation. A keyless bypass module may be available, contact your distributor to find out. If one of these modules is not available to you, see the appropriate security diagram for bypass instructions.
 12 VOLTS BROWN / red Ignition switch harness   +
 IGNITION WHITE/ orange Ignition switch harness   +
 ACCESSORY Violet/green Ignition switch harness   +
 STARTER Blue/white Ignition switch harness   +
 KEY SENSE Blue/gray Ignition switch harness   +
 TACH SIGNAL Use fuel injector
 FUEL INJECTOR Opposite from Gray At any injector on engine   AC
 LOCK Gray / YELLOW In driver's kickpanel   -
 UNLOCK Violet/gray In driver's kickpanel   -
 DOORPIN Blue In driver's kickpanel   +
 R.A.P. SHUT DOWN GREEN/ violet In Blue plug at fuse/junction block under driver's side dash
 This is the driver's doorpin and it rests at ground (-) with the door closed. Use a relay to open this wire which will simulate the door opening and shut down the radio.
 TRUNK PIN Yellow/orange In driver's kickpanel   -
 TRUNK RELEASE Brown At release switch   -
 FACTORY ARM Arms with lock wire
 FACTORY DISARM Violet/brown In driver's kickpanel   -
 If the vehicle is equipped with memory seats, this wire will be located in the driver's door at the main module.
KarTuneMan
Posted: December 09, 2006 at 11:02 PM / IP Logged
 BRAKESWITCH Violet/white At switch above brake pedal   +
 PARKLIGHTS Gray / YELLOW In driver's kickpanel   +
 PARKLIGHTS (-) Gray At light switch harrness   -
 HAND BRAKE Gray/blue At switch on handbrake lever   -
 HORN Blue/white At steering column   -
 DRIVER WINDOW UP blue/gray At switch in driver's door   Rev Pol
 DRIVER WINDOW DOWN Yellow/purple At switch in driver's door   Rev Pol
 PASSENGER WINDOW UP BROWN / yellow In driver's kickpanel harness from door   Rev Pol
 PASSENGER WINDOW DOWN GREEN/ orange In driver's kickpanel harness from door   Rev Pol
 LEFT REAR WINDOW UP Blue/orange In driver's kickpanel harness from door   Rev Pol
 LEFT REAR WINDOW DOWN Yellow In driver's kickpanel harness from door   Rev Pol
 RIGHT REAR WINDOW UP Gray/violet In driver's kickpanel harness from door   Rev Pol
 RIGHT REAR WINDOW DOWN BROWN / green In driver's kickpanel harness from door   Rev Pol
 HEADLIGHTS Blue/white At light switch harness   -
 REVERSE LIGHTS GREEN / WHITE In driver's kickpanel   +
