97 civic domelight????
Signal
Member - Posts: 7
Posted: January 27, 2003 at 9:57 PM / IP Logged
After changing a 97 civic factory radio with keyless entry to a sony aftermarket radio dome light does not work?? Does any one know how to fix it???
Signal
ViperATC5
Copper - Posts: 202
Posted: January 29, 2003 at 6:54 AM / IP Logged
yes, in the green plug that used to plug into the factory radio, connect the light GREEN/ red wire to the light GREEN/ black wire and this will take care of your problem
slobert
Member - Posts: 31
Posted: January 29, 2003 at 6:34 PM / IP Logged
you can keep the keyless also, just wire in a reverse harness and keep the factory radio in the dash....
Tuesday, March 3, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
