2006 Ford Taurus, stereo wiring
bigfonz80
Posted: December 26, 2006 at 8:44 AM / IP Logged
I need a stereo wiring digram to install a harmon kardon i-drive
KarTuneMan
Platinum - Posts: 7,056
Posted: December 26, 2006 at 9:16 AM / IP Logged
+12V DC Battery(Constant)RED / yellow Control unit in left side of luggage compartment 17 20 amp Junction box in front center of engine compt.
Switched AccessoryRED / orange In-line with the starter relay 27 5 amp Junction box in front center of engine compt.
Ground BLACK/ lt.green
Remote Turn On(output) BROWN / orange Pin 8 of CD changer. Also light GREEN/ black between rear control unit (C388B-2) and front panel (pin 4).
Illumination See notes *
Left Front + ORANGE / lt.green
Left Front - Lt.blue/white
Right Front + WHITE/ lt.green
Right Front - Dk.GREEN/ orange
Left Rear + Grey/lt.blue
Left Rear - Tan / YELLOW
Right Rear + ORANGE / red
Right Rear - BROWN / pink
2006 Ford Taurus, stereo wiring -- posted image.  Available Notes
Notes
Information listed in the harness section refers (in this case) to the rear control unit in left side of the luggage compartment.
* Illumination is controlled from the integrated control panel, thru dark blue/white at pin 2.
INTEGRATED CONTROL PANEL has WHITE/ red for battery input (pin 11), with fuse no. 33 of 15 amps in the junction box under left side of dash; BLACK/ pink for acc. power (pin 6), with fuse 22 of 15 amps in the junction box under left side of dash; RED / yellow for hot in start or run (pins 5 & 16), with fuse no. 32 of 10 amps in the same location.
AUDIO connections between the integrated control panel (front) and the rear control unit (rear) are as follows:
R+ dark blue/white wire between pin 9 of front unit & pin C388B-7 of rear unit;
R- gray wire between pin 19 of front unit & pin C388B-20 of rear unit;
L+ BROWN / light green wire between pin 20 of front unit & pin C388B-6 of rear unit;
L- WHITE/ pink wire between pin 10 of front unit & pin C388B-19 of rear unit.
AUDIOPHILE SYSTEM has right and left tweeter speakers branching to right and left front speakers with the same colours.
bigfonz80
Posted: December 28, 2006 at 3:15 PM / IP Logged
thanks!
