2001 Pontiac Gr. Prix
mbsaudio
Copper - Posts: 80
Posted: January 29, 2003 at 5:54 PM / IP Logged
Can someone tell me for sure which anti-theft system this car really has before I start on it.  It should be passkey not passlock2 right?2001 Pontiac Gr. Prix -- posted image.
brianh
Silver - Posts: 518
Posted: January 29, 2003 at 6:53 PM / IP Logged
Here is your info:
|              12V|red                 |+  |ignition harness            |
|          STARTER|yellow              |+  |ignition harness            |
|         IGNITION|pink                |+  |ignition harness            |
|  SECOND IGNITION|white               |+  |ignition harness            |
|        ACCESSORY|orange              |+  |ignition harness            |
|       POWER LOCK|lt. blue            |-  |driver kick panel           |
|     POWER UNLOCK|white               |-  |driver kick panel           |
|       LOCK MOTOR|gray                |   |driver kick panel           |
|     UNLOCK MOTOR|tan                 |   |driver kick panel           |
|    DISARM DEFEAT|tan                 |   |passenger kick panel        |
| PARKING LIGHTS +|brown               |   |at switch                   |
|       HEADLIGHTS|yellow              |+  |at switch                   |
|     DOOR TRIGGER|tan and dark blue   |-  |*1                          |
| DOME SUPERVISION|use door trigger    |   |                            |
|  TRUNK/HATCH PIN|RED / black           |-  |under rear deck             |
|TRNK/HTCH RELEASE|BLACK/ white         |+  |at switch                   |
|FCTRY ALRM DISARM|ORANGE / black        |-  |driver kick panel           |
|       TACHOMETER|PURPLE / white        |   |ECM under hood              |
|      SPEED SENSE|dk.green            |4  |*2                          |
|       BRAKE WIRE|white               |+  |stop light switch           |
|     HORN TRIGGER|black               |-  |steering column             |
|           WIPERS|gray                |+  |steering column             |
|  LF WINDOW UP/DN|dk. blue - brown    |A  |LF window motor in door     |
|  RF WINDOW UP/DN|lt. blue - tan      |A  |drivers kick panel          |
|  LR WINDOW UP/DN|dk. green - purple  |A  |drivers kick panel          |
|  RR WINDOW UP/DN|lt. green - purple  |A  |drivers kick panel          |
Notes:
NOTE:  This vehicle is equipped with the pass-key III immobilizer.  Use DEI part number 555U to bypass during remote start mode.  *1 The tan is located in the drivers kick and catches only the drivers door.  The dark/blue is located in the passenger kick panel and catches all other doors, must diode isolate these wires.   *2  Located at a 10 pin plug on the front of the drivers strut tower. There are two dk.green wires there, use the one in the corner of the plug.
mbsaudio
Copper - Posts: 80
Posted: January 30, 2003 at 5:12 PM / IP Logged
2001 Pontiac Gr. Prix -- posted image.Thanks Brianh.  I was just wondering where you are getting this info from.  I see all the responses to wire colours are in the same format.  Are you guys using a special data base or something.  I currently use Bulldogsecurity site but their info isn't always complete or accurate.
brianh
Silver - Posts: 518
Posted: January 30, 2003 at 5:37 PM / IP Logged
Go to www.velocitymotorsport.com .   This is Jeffs web site,he answers questions here all the time.  He sells a cd from this site that is jam packed with tons of valuble info.  I bought it and it is a great database to have when you install.  You wont be disapointed!   Brian
