2007 Ford Edge Alarm/Remote Start Wiring
orrious
Posted: February 05, 2007 at 1:59 PM / IP Logged
I have a 2007 Ford Edge and I need help finding the wiring diagram for the vehicle to hook up an alarm and remote start system. Any assistance will be greatly appreciated. Thank you
Twelvoltz
Platinum - Posts: 2,384
Posted: February 05, 2007 at 2:51 PM / IP Logged
Audiovox Lists:
          #510367: 2007 FORD EDGE 4DR SUV WITH 2.3L ENGINE AND STANDARD AUDIO SYSTEM
     Audio/Mobile Video
     WIRE          COLOR          POLARITY          LOCATION
     Please select another category
     Security
     Battery          BLUE/RED          (+)          IGNTITION SWITCH
     Ignition 1          WHITE/ ORANGE          (+)          IGNTITION SWITCH
     Starter 1          BLUE/WHITE          (+)          IGNTITION SWITCH
     All Door Trigger          GRAY/VIOLET          (+)          DRVERS KICK PANEL
     Alarm Disarm          VIOLET/BROWN          (-)          IGNTITION SWITCH
     Parking Lights          WHITE          (-)          HEADLAMP SWITCH NEED RELAY
               SEE DOCUMENT FOR DIAGRAM
     Convenience
     Headlights-Lo          VIOLET/GREEN          (+)          HEADLIGHT SWITCH NEED RELAY
               SEE DOCUMENTS FOR TECH TIP
     Trnk Release          GRAY / YELLOW          (-)          LIFTGATE SWITCH
     Remote Start
     Accessory 1          VIOLET/GREEN          (+)          IGNITION SWITCH
     Key Sense          BLUE/GRAY          (+)          IGNITION SWITCH
     Brake Lights          VIOLET/WHITE          (-)          BRAKE SWITCH
     Horn          BLUE/WHITE          (-)          STEERING COLUMN HARNESS
     Modules
     WIRE          LOCATION
     Doorlocks/Windows
     Door Lock Circuit          3 WIRE NEG
     Power Unlock          VIOLET/GRAY          (-)          DRIVERS KICK PANEL
     PowerLock          GRAY / YELLOW          (-)          DRIVERS KICK PANEL
     Driver Mtr Unlock          BLUE/GREEN          (REV)          DRIVERS KICK PANEL
     Driver Mtr Lock          GRAY/BROWN          (REV)          DRIVERS KICK PANEL
     Pas Mtr Unlock          VIOLET/GRAY          (REV)          DRIVERS KICK PANEL
     Note: Audiovox makes no representation or warranty with respect to the above information including its accuracy, completeness, or its freedom from third parties' proprietary rights. Audiovox disclaims all liability or responsibility for errors or omissions therein or any decision made by the recipient in reliance thereon. The installer must verify any circuitry with the proper test equipment prior to installation.
The tech document they refer to can be found here. Looks like the same parking light isolation diagram as what was used in the Windstars.
Bypasskit.com lists this for a bypass.
mikvot
Gold - Posts: 1,043
Posted: February 05, 2007 at 5:14 PM / IP Logged
All of the wires that say "at ignition harness" can also be found at drivers kick, including all wires for remote start.
Wednesday, January 7, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
