cd player wiring to factory wires
rcampbell37
Posted: February 19, 2007 at 10:29 PM / IP Logged
1997 Geo Metro The wires were cut and I need the wiring diagram to wire it up.
warpedimage3
Copper - Posts: 90
Posted: February 20, 2007 at 2:50 PM / IP Logged
directechs doesnt list anything diagrams for this car.  you will probably be better off getting a DMM and testing the wires it doesnt take too long.
rcampbell37
Posted: February 21, 2007 at 10:57 PM / IP Logged
What is a DMM ? Thank you.
Installer_mss
Copper - Posts: 221
Posted: February 26, 2007 at 6:12 PM / IP Logged
it should be normal GM wiring:
12v constant - orange
accessory - yellow
ground - black
dimmer/illumination - gray
power ant. - pink (if applicable)
FL spkr - tan +, gray -
FR spkr - lt. green +, dk. green -
RL spkr - brown +, yellow -
RR spkr - dk. blue +, lt. blue -
DMM = Digital MultiMeter
use a DMM or test light to check for the accessory and dimmer wire, then the rest are speaker wires
"If a man made it, another can modify it...it just takes some thinking."
"If you ask questions, you're a fool for 5 minutes; if you don't, you're a fool for a lifetime."
Tuesday, May 19, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
