1997 gmc yukon wiper switch wire
bigtoxy
Posted: March 01, 2007 at 6:25 PM / IP Logged
I'm Installing a DEI 545T Nite-Lite Module and I need the Wiper Output wire color and location, So the lights on when Wipers are turned on. Thanks in advance
master5
Silver - Posts: 1,123
Posted: March 01, 2007 at 6:33 PM / IP Logged
Without a FSM I can't say off hand..perhaps someone will come through.
If not...try this.Drop the panals under the dash and probe the thinner wires coming down the steering column (don't touch any SRS (yellow or orange covered harnesses) and read with A DMM what the wires do when you turn the wipers on and off..there shouldn't be too many wires coming from that stalk area.
Good Luck
flobee4
Silver - Posts: 585
Posted: March 01, 2007 at 7:29 PM / IP Logged
here you, go happy wiring
DIRECTWIRE™ WIRING INFORMATION - GMC / YUKON / 1997 / Accessory
[PRINT THIS PAGE]
12volts
red
ignition harness
Ignition
pink
ignition harness
Parking Lights+
brown
headlight switch
Parking Lights-
Headlight
yellow
headlight switch
Trunk/Hatch Release
black or blk/wht
low in the drivers kick
Notes: positive trigger on models with rear lift window, and 5 wire on models with cargo doors.
Power Sliding Door
Speed Sense
green
4
ECM
Notes: ECM is located on drivers side inner fender. Tach wire found in a black plug marked *white*.
Wipers
purple
steering column
LF Window up/dn
dk. blue - brown
A
at drivers door switch
RF Window up/dn
light blue - tan
A
dr door or kick panel
LR Window up/dn
dk. grn - purple
A
drivers kick panel
RR Window up/dn
lt. grn - purple
A
drivers kick panel
master5
Posted: March 02, 2007 at 10:42 AM / IP Logged
doh..I should have thought of directtech,,I didn't think they would list the wipers but it is a DEI part..but...it can never hurt to learn how to find wires yourself if need be.
Enjoy
bigtoxy
Posted: March 02, 2007 at 7:17 PM / IP Logged
Thanks Very Much!
Sunday, February 15, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
