1995 Chevy Cavalier
barnuf
Posted: February 07, 2003 at 11:12 AM / IP Logged
I am installing the alarm on my 1995 Chevy Cavalier Sedan, 4dr (manual gear shift, 2200), and i was wondering whether someone here has the wiring diagram for my car??
Thanx for the help...
Bnluis
Silver - Posts: 578
Posted: February 07, 2003 at 11:49 AM / IP Logged
1995 Cavalier
|              12V|red                 |+  |ignition harness            |
|          STARTER|yellow              |+  |ignition harness            |
|         IGNITION|pink                |+  |ignition harness            |
|  SECOND IGNITION|white               |+  |ignition harness            |
|        ACCESSORY|orange              |+  |ignition harness            |
|       POWER LOCK|lt. blue            |5wi|either kick panel *2        |
|     POWER UNLOCK|white               |5wi|either kick panel *2        |
| PARKING LIGHTS +|brown               |   |harness to rear, dkp        |
|       HEADLIGHTS|dk. blue            |-  |headlight switch            |
|     DOOR TRIGGER|grn/blk & lt. blue  |-  |*3                          |
|  TRUNK/HATCH PIN|black               |-  |trunk light                 |
|TRNK/HTCH RELEASE|BLACK/ white         |+  |keyless module *4           |
|       TACHOMETER|*1                  |   |engine harness *1           |
|       BRAKE WIRE|white               |+  |stop light switch           |
|     HORN TRIGGER|black               |-  |steering column             |
|           WIPERS|                    |   |                            |
|  LF WINDOW UP/DN|dk. blue - brown    |A  |LF window motor in door     |
|  RF WINDOW UP/DN|lt. blue - tan      |A  |drivers kick panel          |
|  LR WINDOW UP/DN|dk. green - purple  |A  |drivers kick panel          |
|  RR WINDOW UP/DN|lt. green - purple  |A  |drivers kick panel          |
Notes:
NOTE: This vehicle has a the PASSLOCK I key based engine disabling system. Use DEI part number 555t or 555L to bypass during remote start.  *1 The engine harness is found next to the battery, below the radiator hose, just above the transaxle. Use white or orange on the 2.2L motor, and PURPLE / white on the 2.3L motor.  *2 Locks are mastered from the passenger side.  *3 The GREEN/ black is located in the lower drivers kick panel. It catches the drivers door only. The light blue is located in the lower passenger kick panel, and catches the passenger door(s). Tap both wires and diode isolate each.  *4 The keyless module is located in the left side of the trunk behind the rear seat.
Luis
Sound Waves
Is up to the installer to test all wires with a DMM whenever possible.
Thursday, April 23, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
