2004 acura mdx factory amp wiring
Copper - Posts: 93
Posted: June 02, 2007 at 12:33 PM / IP Logged
hi, anyone have the wiring info for the factory amp for a 2004 acura mdx? the amp is mounted right behind the center console, lower center, against the firewall. any help would be great. thanks!
wire4veins
Copper - Posts: 97
Posted: June 20, 2007 at 10:44 PM / IP Logged
Radio 12v
      white or WHITE/ blue
      radio harness
Radio Ground      black       -       radio harness
Radio Ignition      WHITE/ red       +       radio harness
Radio Illumination      RED / black       +       radio harness
Factory Amp Turn-on      same as power antenna wire
Power Antenna      yellow/white       +       radio harness
LF Speaker +/-      blue/green - gray/black       +,-      radio harness or amp under ctr dash
RF Speaker +/-      RED / green - BROWN / black       +,-      radio harness or amp under ctr dash
LR Speaker +/-      blue / YELLOW - gray/white       +,-      radio harness or amp under ctr dash
RR Speaker +/-      RED / yellow - BROWN / white       +,-      radio harness or amp under ctr dash
wire4veins
"D"
Precision Autosound - Owner
MECP Master Installer
