86 Toyota Corolla SR5 Alarm/Remote Start Wiring
shinobi_magic
Member - Posts: 6
Posted: May 27, 2002 at 1:49 AM / IP Logged
i am re-doing an 86 toyota corolla sr5, i was wondering were i can get a wire diagram on this car, i am removing the stereo wire and running a second alt and battery setup, i have been told by many people that it is much harder on this car then it was on my 72 camaro please help me
what i can't hear you, i need a bigger stereo my brother in japan can't hear it
Platinum - Posts: 12,488
Posted: May 27, 2002 at 4:46 AM / IP Logged
Toyota
Corolla
1985-1987
Remote Starter  Wiring Colors and Notes
Function
Vehicle  Color
Location
Start:
BLACK/ WHITE
IGNITION SWITCH HARNESS
Ignition  #1:
BLACK/ ORANGE
Ignition #2:
BLACK / YELLOW
Ignition  #3:
N/A
Accessory:
BLUE/RED
Brake  Light:
GREEN / WHITE (+)
SWITCH ON BRACKET ABOVE BRAKE PEDAL
Tach  Signal:
BLACK / YELLOW
Parking Lights:
GREEN
(+) AT FUSE BOX
Headlights:
RED / WHITE
(-) AT HEADLIGHT SWITCH
OEM Alarm  Disarm:
N/A
OEM Alarm  Arm:
N/A
Diesel  Glow Plug:
Clutch  Bypass Wire:
Notes:
 * Some Models Carburated.
Toyota
Corolla
1985-1987
Alarm and Keyless  Entry Wiring Colors and Notes
Function
Vehicle  Color
Location
Constant  +12 Volts:
BLACK/ RED OR WHITE
Starter  Kill:
BLACK/ WHITE
Ignition  +12 Volts:
BLACK/ ORANGE
Dome  Lights/Superv:
RED / WHITE
(-) PASSENGER PIN SWITCH
OEM Horn:
GREEN/ RED (-)
STEERING COLUMN HARNESS OR AT RELAY
Power  Lock:
BLUE/WHITE
DRIVER'S KICK PANEL **
Power  Unlock:
BLUE/RED
Trunk  Release:
N/A
Alarm  Input Wire:
RED / WHITE
Notes:
** Negative Pulse Door Lock Diagram.
