2007 saturn outlook
allmet33
Copper - Posts: 112
Posted: June 18, 2007 at 12:38 PM / IP Logged
with the upgraded audio system.
I really just need to identify the wires for the rear speakers so I can tap a hi/lo converter into them to add an aftermarket amp.
'06 Hyundai Azera - Pioneer FH-P4200MP / Factory center channel & tweeters / Infinity Kappa 62.7i's; all 4 doors, 2 Phoenix Gold Xenon 10D2 10" subs pushed w/Phoenix Gold Xenon 600.1 amp
klutch240
Member - Posts: 9
Posted: June 19, 2007 at 9:41 PM / IP Logged
if the rear speakers are easy to pull, pop em out and look at the wire colors. They should be the same at the stereo.
Klutch
klutch240
Member - Posts: 9
Posted: June 19, 2007 at 10:09 PM / IP Logged
Or as it end up I have the info
Right rear DK blue (+) Lt blue (-)
left rear Brown (+) yeloow (-)
this is according to directech.com
its says you can get these at the radio harness or at the amp above the drivers kick pannel.
also White (+) at the radio harness is the power antenna or remote wire.
Klutch
Friday, January 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
