05 Chrysler PT Cruiser Convertible Alarm/Remote Start Wiring
guinness2
Posted: June 27, 2007 at 2:11 PM / IP Logged
Can anyone help me with a complete security,remote start wiring diagram for this car?
KarTuneMan
Platinum - Posts: 7,056
Posted: June 27, 2007 at 2:58 PM / IP Logged
 PASSIVE ANTI-THEFT YES TRANSPONDER   SEE NOTES
 12 VOLTS Pink/black Ignition switch harness   +
 IGNITION Blue Ignition switch harness   +
 ACCESSORY BLACK/ orange Ignition switch harness   +
 STARTER Yellow Ignition switch harness   +
 KEY SENSE Lt.blue Ignition harness   -
 TACH SIGNAL BLACK/ gray At PCM under hood   AC
 The PCM is located on the driver's side firewall under the hood. The BLACK/ GRAY is found in the gray connector.
 LOCK WHITE/ green Above driver's kickpanel   -
 This vehicle uses multiplexing where a single wire performs all lock and security functions, resistors are required. See the DOORLOCKS diagram for wiring details.
 UNLOCK WHITE/ green Above driver's kickpanel   -
 DOORPIN SEE NOTES White connector in driver's kickpanel   -
 TAN (driver's door), BLUE/ORANGE or BLUE (all other doors). Both wires are found in a WHITE connector in the driver's kickpanel.
 TRUNK PIN Tan/black White connector in driver's kickpanel   -
 FACTORY ARM WHITE/ green Above driver's kickpanel   -
 FACTORY DISARM WHITE/ green Above driver's kickpanel   -
 BRAKESWITCH WHITE/ tan In driver's kickpanel   +
 It is recommended that you use the wire found in the driver's kickpanel and not the one at the brakeswitch itself.
 PARKLIGHTS BLACK / YELLOW At steering column   +
 HAND BRAKE Gray/black Front right side of shifter   -
 HORN BLACK/ red At steering column   -
guinness2
Posted: June 28, 2007 at 6:44 PM / IP Logged
Thank you for your quick response .
