2001 dodge durango vss location
shhnappa
Member - Posts: 23
Posted: September 12, 2007 at 11:26 PM / IP Logged
Hi Folks, I was wondering if anyone can help me out with the VSS wire color and location on a 2001 Dodge Durango. I have searched the forum, and have found nothing. You guys have been very helpfull on my other two personal installs, so I figured I'd go back to the well. Any help would be much appreciated.
kola7126
Copper - Posts: 93
Posted: September 13, 2007 at 2:53 PM / IP Logged
+12 red  -steering column. IGNITION   -d\blue-  steering column, STARTER -yellow-  steering column, PARKING LIGHT(+) -black\yellow-  STOP(+) -white\brown- left kick panel, DOOR TRIGGER(-) black\blue(driver), l.brown\red (pass.),l.brown\black (rear), DOOR LOCK -orange\purple,DOOR UNLOCK -pink\purple-.
KarTuneMan
Platinum - Posts: 7,056
Posted: September 15, 2007 at 7:32 PM / IP Logged
 REVERSE LIGHTS Violet/black In driver's kickpanel   +
 VSS WIRE WHITE/ orange Pin-27 on C2 connector at PCM   8000ppm
 Located on the right front inner fender.
 DATABUS INTERFACE Pin-2(top row from left) Diagnostic plug below dash   DATA
Monday, April 6, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
