2008 Toyota Camry VSS Wire Color?
baovuong
Member - Posts: 21
Posted: September 25, 2007 at 1:25 PM / IP Logged
HI
Anybody know the location and the color of the Vss wire for Toyota Camry 2008?
Is it the same as the Camry 2007? or the Camry 2008 use Can bus system?
Thanks for the help!
KarTuneMan
Platinum - Posts: 7,056
Posted: September 26, 2007 at 10:24 PM / IP Logged
BRAKESWITCH White In gray plug on right of fusebox under dash   +
 PARKLIGHTS Green In white plug on front of fusebox   +
 PARKLIGHTS (-) Black At light switch harness on steering column   -
 HAND BRAKE Blue At switch on handbrake lever above DKP   -
 HORN White In black plug on steering column   -
 CLUTCH SWITCH Green At switch on clutch pedal bracket   Type 1
 REVERSE LIGHTS White Driver's kickpanel in harness to rear   +
 VSS WIRE Violet In radio harness behind radio   AC
