2002 ford taurus, cruise, stereo wiring
shadowhonda2002
Posted: November 20, 2007 at 6:12 PM / IP Logged
Can any please get a cruise control wiring diagram and for the stereo that actually works
KarTuneMan
Platinum - Posts: 7,056
Posted: November 21, 2007 at 9:27 PM / IP Logged
Cruise control wiring diagram....... ?2002 ford taurus, cruise, stereo wiring -- posted image. What?
12V DC Battery(Constant)Yellow Control unit in left side of luggage compartment 17 20 amp Junction box in front center of engine compt.
Switched AccessoryRED / orange In-line with the starter relay 27 5 amp Junction box in front center of engine compt.
Ground BLACK/ lt.green
Power Antenna RED / pink
Remote Turn On(output) Lt.GREEN/ black Pin 8 of CD changer. Also light GREEN/ black between rear control unit (C388B-2) and front panel (pin 4).
Left Front + ORANGE / lt. green
Left Front - Lt.blue/white
Right Front + WHITE/ lt.green
Right Front - Dk.GREEN/ orange
Left Rear + Grey/lt. blue
Left Rear - Tan / YELLOW
Right Rear + ORANGE / red
Right Rear - BROWN / pink
2002 ford taurus, cruise, stereo wiring -- posted image. AT SPEAKERS
Wire FunctionColorNote
Left Front Tweeter + ORANGE / lt.green If equipped
Left Front Tweeter - Lt.blue/white If equipped
Right Front Tweeter + WHITE/ lt.green If equipped
Right Front Tweeter - Dk.GREEN/ orange If equipped
2002 ford taurus, cruise, stereo wiring -- posted image.  Available Notes
Notes
Information listed in the harness section refers (in this case) to the rear control unit in left side of the luggage compartment.
INTEGRATED CONTROL PANEL has WHITE/ red for battery input (pin 11), with fuse no. 16 of 15 amps, BLACK/ pink for acc. power (pin 6), with fuse no. 11 of 15 amps, RED / yellow for hot in start or run (pin 16), with fuse no. 27 of 10 amps; these fuses are in the central junction box.
AUDIO connections between the integrated control panel (front) and the rear control unit (rear) are as follows:
R+ dark blue/white wire between pin 9 front & pin C388B-7 rear
R- gray wire between pin 19 front & pin C388B-20 rear
L+ BROWN / light green wire between pin 20 front & pin C388B-6 rear
L- WHITE/ pink wire between pin 10 front & pin C388B-19 rear
