2008 Toyota Corolla Alarm/Remote Start/Stereo Wiring
chev104275
Gold - Posts: 1,436
Posted: December 06, 2007 at 6:28 AM / IP Logged
Does anyone have a wiring diagram for a 2008 toyota corolla im installing a keyless entry and remote start system   thanks in advance Joe
Twelvoltz
Platinum - Posts: 2,384
Posted: December 06, 2007 at 6:41 AM / IP Logged
Audiovox Lists:
          #513362: 2008 TOYOTA COROLLA 4DR SEDAN WITH 4-SPEAKER AUDIO SYSTEM
     Audio/Mobile Video
     WIRE          COLOR          POLARITY          LOCATION
     Battery          BLUE/WHITE          (+)          RADIO HARNESS
     Accesory          GREY          (+)          RADIO HARNESS
     Ground          BROWN          (-)          RADIO HARNESS
     Illumination          GREEN          (+)          RADIO HARNESS
     Dimmer          WHITE/ BLACK          (-)          RADIO HARNESS
     Power Antenna          BLACK          (+)          RADIO HARNESS
     LF Speaker (+)          PINK
     LF Speaker (-)          VIOLET
     RF Speaker (+)          LT. GREEN
     RF Speaker (-)          BLUE
     LR Speaker (+)          BLACK
     LR Speaker (-)          YELLOW
     RR Speaker (+)          RED
     RR Speaker (-)          WHITE
     Amp Location          UNDER REAR SEAT
     Steering Cntrls          NO
     Speed Cntrl          NO
     Radio Security          YES
     Security
     Battery          BLACK AND WHITE          (+)          IGNITION SWITCH HARNESS
     Ignition 1          BLACK / YELLOW          (+)          IGNITION SWITCH HARNESS
     Starter 1          RED          (+)          IGNITION SWITCH HARNESS
     All Door Trigger          RED          (-)          INTERGATION RELAY LEFT SIDE DASH BEHIND FUSEBOX
               6 PIN GRAY CONN.
     Domelight Super          RED          (-)          INTERGATION RELAY LEFT SIDE DASH BEHIND FUSEBOX
               6 PIN GRAY CONN.
     LF Latch          RED / WHITE          (-)          AT THEFT MODULE BEHIND RIGHT SIDE OF DASH NEXT TO GLOVEBOX
     RF Latch          RED          (-)          AT THEFT MODULE BEHIND RIGHT SIDE OF DASH NEXT TO GLOVEBOX
     LR Latch          RED          (-)          AT THEFT MODULE BEHIND RIGHT SIDE OF DASH NEXT TO GLOVEBOX
     RR Latch          RED          (-)          AT THEFT MODULE BEHIND RIGHT SIDE OF DASH NEXT TO GLOVEBOX
     Trunk Trigger          RED / WHITE          (-)          AT TRUNK LIGHT
     Alarm Disarm          DISARMS WITH UNLOCK
     Parking Lights          GREEN / WHITE          (-)          AT SWITCH
     Convenience
     Headlights-Lo          RED          (-)          AT VEHICLE LIGHT SWITCH HARNESS
     Headlights-Hi          RED / YELLOW          (-)          AT VEHICLE LIGHT SWITCH HARNESS
     LF Pk Lt Bulb          GREEN          (+)          AT FRONT LEFT PARKING LIGHT
     RF Pk Lt Bulb          GREEN          (+)          AT FRONT RIGHT PARKING LIGHT
     LR Pk Lt Bulb          GREEN          (+)          AT REAR LEFT PARKING LIGHT
     RR Pk Lt Bulb          GREEN          (+)          AT REAR RIGHT PARKING LIGHT
     All Hazrd Lights          YELLOW/BLACK          (-)          AT VEHICLE HAZARD LIGHT SWITCH
     LF Hazrd Bulb          GREEN/ BLACK          (+)          AT FRONT LEFT DIRECTIONAL LIGHT
     RF Hazrd Bulb          GREEN/ YELLOW          (+)          AT FRONT RIGHT DIRECTIONAL LIGHT
     LR Hazrd Bulb          GREEN/ BLACK          (+)          AT REAR LEFT DIRECTIONAL LIGHT
     RR Hazrd Bulb          GREEN/ YELLOW          (+)          AT REAR RIGHT DIRECTIONAL LIGHT
     Wipers-Lo          BLUE/WHITE          (+)          AT VEHICLE WIPER SWITCH HARNESS
     Wipers-Hi          BLUE/RED          (+)          AT VEHICLE WIPER SWITCH HARNESS
     Parking Brake          RED / BLACK          (-)          AT PARKING BRAKE SWITCH HARNESS
     Trnk Release          BLUE/WHITE          (-)          AT THEFT MODULE BEHIND RIGHT SIDE OF DASH NEXT TO GLOVEBOX
               PIN #23
     Remote Start
     Ignition 2          BLACK/ WHITE          (+)          IGNITION SWITCH HARNESS
     Accessory 1          BLUE/RED          (+)          IGNITION SWITCH HARNESS
     Anti-Theft Type          TRANSPONDER TYPE
     Key Sense          BLUE/BLACK          (-)          IGNITION HARNESS
               STATUS OUTPUT DURING REMOTE START WILL DISARM ALARM WITHOUT UNLOCKING DOORS
     Tachometer          UNCOMMON COLOR          (AC)          ANY FUEL INJECTOR
               PIN #5
     Speed Sense          VIOLET/WHITE          (+)          AT GAUGE CLUSTER HARNESS BEHIND DASH
     Brake Lights          GREEN / WHITE          (+)          AT SWITCH ABOVE BRAKE PEDAL
     Reverse Lights          RED / BLUE          (+)          BEHIND GLOVE BOX
     Horn          GREEN/ YELLOW          (-)          STEERING COLUMN HARNESS
     Modules
     WIRE          LOCATION
     Module 1          ECM IS BEHIND GLOVEBOX
     Doorlocks/Windows
     Power Unlock          BLUE / YELLOW          (-)          DRIVERS KICK PANEL
               OR BLUE IN THE KICK PANEL.. DOUBLE PULSE
     PowerLock          GREEN          (-)          DRIVERS KICK PANEL
               OR BLUE/WHITE IN KICK PANEL.. PIN #7 & #19 - YOU MUST DIODE ISOLATE THE UNLOCK PULSE FROM THE ALARM UNIT TO AVOID FEEDBACK.
     Driver Mtr Unlock          RED          (REV)          DRIVERS KICK PANEL
     Driver Mtr Lock          BLUE          (REV)          DRIVERS KICK PANEL
     Pas Mtr Unlock          RED          (REV)          DRIVERS KICK PANEL
     Pas Mtr Lock          BLUE          (+)          AT MOTOR IN DOOR
     LF Window Up          YELLOW          (REV)          AT MASTER SWITCH IN DRIVERS DOOR
     LF Window Dn          GREEN          (REV)          AT MASTER SWITCH IN DRIVERS DOOR
     RF Window Up          BLACK/ RED          (REV)          AT MASTER SWITCH IN DRIVERS DOOR
     RF Window Dn          BLACK/ WHITE          (REV)          AT MASTER SWITCH IN DRIVERS DOOR
     LR Window Up          RED / BLUE          (REV)          AT MASTER SWITCH IN DRIVERS DOOR
     LR Window Dn          BLUE          (REV)          AT MASTER SWITCH IN DRIVERS DOOR
     RR Window Up          RED / BLACK          (REV)          AT MASTER SWITCH IN DRIVERS DOOR
     RR Window Dn          RED          (REV)          AT MASTER SWITCH IN DRIVERS DOOR
     Sunroof Open          GREEN          (+)          AT SUNROOF SWITCH HARNESS
     Sunroof Close          RED          (+)          AT SUNROOF SWITCH HARNESS
     Note: Audiovox makes no representation or warranty with respect to the above information including its accuracy, completeness, or its freedom from third parties' proprietary rights. Audiovox disclaims all liability or responsibility for errors or omissions therein or any decision made by the recipient in reliance thereon. The installer must verify any circuitry with the proper test equipment prior to installation.
chev104275
Gold - Posts: 1,436
Posted: December 06, 2007 at 6:50 AM / IP Logged
would i be able to use a 556uw bypass ?
Twelvoltz
Posted: December 06, 2007 at 7:04 AM / IP Logged
According to this no you can not use a U it has to be a data interface.
chev104275
Gold - Posts: 1,436
Posted: December 06, 2007 at 7:16 AM / IP Logged
sorry i had the wrong car written down its a 2008 camry   i need a diagram for    thanks again Joe
chev104275
Gold - Posts: 1,436
Posted: December 06, 2007 at 8:06 PM / IP Logged
is the diagram the same as an 2007 for a 2008 ? thanks again Joe
Twelvoltz
Posted: December 07, 2007 at 9:15 AM / IP Logged
Audiovox lists:
          #513592: 2008 TOYOTA CAMRY 4DR SEDAN WITH 2.4L ENGINE AND JBLŽ 8-SPEAKER AUDIO SYSTEM
     Audio/Mobile Video
     Battery          BLUE & BLUE YELLOW          (+)          RADIO HARNESS
     Accesory          GRAY          (+)          RADIO HARNESS
     Power Antenna          ORANGE          (+)          RADIO HARNESS
     Amp Turn On
               THE AMPLIFIER TURNS ON WITH THE ACCESSORY POWER IN THE VEHICLE
     LF Speaker (+)          BLACK
               THESE WIRES PROVIDE THE AUDIO INPUT TO THE AMPLIFIER
     LF Speaker (-)          WHITE
     RF Speaker (+)          RED
     RF Speaker (-)          GREEN
     Amp Location          UNDER THE FRONT RIGHT SEAT
     Steering Cntrls          YES
     Speed Cntrl          YES
     Radio Security          YES
     Security
     Battery          BLACK          (+)          IGNITION SWITCH HARNESS
     Ignition 1          YELLOW          (+)          IGNITION SWITCH HARNESS
     Starter 1          BLUE          (+)          IGNITION SWITCH HARNESS
     All Door Trigger          BROWN          (-)          AT VEHICLE FUSEBOX
     Domelight Super          BROWN          (-)          AT VEHICLE FUSEBOX
     LF Latch          BLUE          (-)          AT BECU MODULE IN VEHICLE FUSEBOX
     RF Latch          YELLOW          (-)          AT BECU MODULE IN VEHICLE FUSEBOX
     LR Latch          LIGHT GREEN          (-)          AT VEHICLE FUSE BOX
     RR Latch          GRAY          (-)          AT BECU MODULE IN VEHICLE FUSEBOX
     Trunk Trigger          WHITE          (-)          AT BECU MODULE IN VEHICLE FUSEBOX
     Hood Trigger          RED          (-)          AT VEHICLE HOOD PIN SWITCH
     Alarm Disarm          BLUE          (-)          INGITION SWITCH HARNESS
     Parking Lights          BLACK          (-)          AT BECU MODULE IN VEHICLE FUSEBOX
     Convenience
     Headlights-Lo          PINK          (-)          AT BECU MODULE IN VEHICLE FUSEBOX
     All Hazrd Lights          WHITE          (-)          AT VEHICLE HAZARD SWITCH
     Wipers-Lo          PINK          (+)          AT WIPER CONTROL SWITCH
     Wipers-Hi          GREEN          (+)          AT WIPER CONTROL SWITCH
     Parking Brake          YELLOW          (-)          AT PARKING BRAKE SWITCH
               MAY ALSO BE BLUE ON SOME MODELS
     Trnk Release          BLACK          (REV)          AT BECU MODULE IN VEHICLE FUSEBOX
     Remote Start
     Ignition 2          PINK          (+)          IGNITION SWITCH HARNESS
     Accessory 1          WHITE          (+)          IGNITION SWITCH HARNESS
     Starter 2          GRAY          (+)          IGNITION SWITCH HARNESS
     Anti-Theft Type          UNIVERSAL IMMOBILIZER
     Anti-Theft Descript          THE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
     Key Sense          BLUE          (-)          IGNITION SWITCH HARNESS
               THIS WIRE WILL DISARM THE FACTORY SECURITY WITHOUT UNLOCKING THE DOORS
     Tachometer          BLACK          (AC)          AT DATALINK CONNECTOR UNDER DRIVER DASH
     Speed Sense          VIOLET          (AC)          RADIO HARNESS
               ALSO AT AMPLIFER UNDER PASSENGER SEAT
     Brake Lights          WHITE          (+)          AT SWITCH ABOVE BRAKE PEDAL
     Reverse Lights          RED          (+)          IN HARNESS IN DRIVER KICKPANEL
     Horn          WHITE          (-)          AT VEHICLE FUSE BOX
     Modules
     WIRE          LOCATION
     Please select another category
     Doorlocks/Windows
     Power Unlock          GRAY          (-)          IN HARNESS IN DRIVERS KICKPANEL
               USE A DOUBLE PULSE TO UNLOCK ALL DOORS
     PowerLock          BROWN          (-)          IN HARNESS IN DRIVERS KICKPANEL
     LF Window Up          GREEN          (REV)          AT DRIVER WINDOW SWITCH
     LF Window Dn          BROWN          (REV)          AT DRIVER WINDOW SWITCH
     RF Window Up          WHITE          (REV)          IN HARNESS IN DRIVER KICKPANEL
     RF Window Dn          RED          (REV)          IN HARNESS IN DRIVER KICKPANEL
     LR Window Up          BLUE          (REV)          IN HARNESS IN DRIVER KICKPANEL
     LR Window Dn          BLACK          (REV)          IN HARNESS IN DRIVER KICKPANEL
     RR Window Up          YELLOW          (REV)          IN HARNESS IN DRIVER KICKPANEL
     RR Window Dn          LIGHT GREEN          (REV)          IN HARNESS IN DRIVER KICKPANEL
     Sunroof Open          BROWN          (-)          AT SUNROOF CONTROL SWITCH
     Sunroof Close          BLUE          (-)          AT SUNROOF CONTROL SWITCH
Same info for bypass module.
