eclipse avn2454 speed sensor wire
bosanci28
Member - Posts: 11
Posted: May 15, 2008 at 6:12 PM / IP Logged
i have a eclipse avn 2454 and i have the speed sensor wire ,,but where exactly this should go to what wire ?,,
the plug that come from the back has 3 wires:
-green
-PURPLE / with white line- speed sensor wire
-RED / with wihte line
my dvd is playing but only in a backround,,if i want to acces ""dvd map error" i get,,
im working in a 2002 escalade
any help will be apreciate,,
bosanci28
Member - Posts: 11
Posted: May 15, 2008 at 9:18 PM / IP Logged
fixed the video,,
red wire to ground!,work,all ther way
but where do i connect the speed sensor wire?
and maybe someone has the 2002 escalade cadilac wiring diagram,,
thanks
Platinum - Posts: 13,726
Posted: May 15, 2008 at 9:30 PM / IP Logged
Did you look to the left of here, in the Vehicle Wiring Database.  Last item listed in Car Audio and Mobile Video, Car Security and Convenience, or Cruise Control sections.  It is listed under the Cruise section.
bosanci28
Member - Posts: 11
Posted: May 15, 2008 at 9:52 PM / IP Logged
sorry man,,i looked but did not find ,,but with
your guide ,,i find i think what i need
on this page
h..p://www.the12volt.com/installbay/forum_posts.asp~TID~7197
for 2002 escalade ext,, should be the same,,the wiring:
for :SPEED SENSE|dk.GREEN / WHITE      |   |ECM *3
(*3 ECM is located near the battery, down low, between the fender and the fan under the black plastic cover.)
so i guess this is the wire that i have find,,and connect with my spped sensor wire
thanks
