03 expedition factory dvd w new head unit
jaketime81
Member - Posts: 12
Posted: July 29, 2008 at 1:39 PM / IP Logged
How do you keep the factory overhead working with an aftermarket h/u.  the factory deck has beed destoyed because of stuck cd's inside and I have no way of determining which wires are used to power up the factory overhead/dvd. I have a small 4pin harness and a larger 20 pin harness colors are as follows:
4pin harness:
GREEN/ purple, black, BLACK/ orange, RED / black
20 pin harness:
brown, blue/red, lt. GREEN/ black, blue, grey/black, lt. blue/red, black, red, black, white, lt.green.
any info is appriciated.
jake
megaman
Copper - Posts: 385
Posted: July 29, 2008 at 4:28 PM / IP Logged
On the large plug:
Pin 5 Lt. GREEN/ Black:  power this as Ignition, this turns on the Overhead.
Audio:
Pin 19 White: Audio L(+)
Pin 20 Lt. Green: Audio L (-)
Pin 17 Red: Audio R (+)
Pin 18 Black: Audio R (-)
Audio lines are low level so connect RCA ends to them and connect them to your aux input on the new deck.
Monday, February 2, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
