two flipdown screens
twank27
Member - Posts: 29
Posted: August 29, 2009 at 1:11 AM / IP Logged
i install two flipdowns in a 2000 crown vic today and when we start the car we get rolling lines in the screens what is the problem this is the first this has happen to me can some help me out please.
if u can't crank it yank it sunnyside.tx
Platinum - Posts: 13,725
Posted: August 29, 2009 at 6:27 PM / IP Logged
Is there a 12Vdc to 110Vac inverter powering your video source?
twank27
Member - Posts: 29
Posted: August 30, 2009 at 1:24 AM / IP Logged
NO THEY ARE GROUND TO CHASSIS AND RAN TO THE FUSE BOX
Posted: September 02, 2009 at 5:58 AM / IP Logged
A Video source is a DVD player or a Playstation, Etc.
twank27
Member - Posts: 29
Posted: September 03, 2009 at 1:14 AM / IP Logged
TOUCHSCREEN PYLE INDASH
yimke
Copper - Posts: 417
Posted: September 04, 2009 at 1:53 PM / IP Logged
Switch units or get a signal amplifier. The voltage output is not enough to run those 2 screens for you. Or if the RCA shielding is touching a ground, that could possibly do it as well.
ceasar326
Copper - Posts: 239
Posted: September 04, 2009 at 3:33 PM / IP Logged
Get a video amp. That always helps the problem
twank27
Member - Posts: 29
Posted: September 04, 2009 at 3:38 PM / IP Logged
i installed a video amp and the still have rollin lines
Posted: September 04, 2009 at 3:52 PM / IP Logged
Get a new "Name Brand" indash.    Before doing that, test it by temporarily connecthing  a home DVD player in place of the Pyle unit.  If the noise goes away, get a new deck.  If the noise is still visible, new monitors may be in order.
