2011 toyota sienna oem backup camera
mangolango
Member - Posts: 11
Posted: May 27, 2011 at 12:40 AM / IP Logged
I want to install Alpine head unit in my Sienna but dunno which wire to tap from OEM camera to my Alpine unit?? The Multi display have bunch of wire but dunno which is video feed?? Please help!!
Mike M2
Platinum - Posts: 2,652
Posted: May 27, 2011 at 6:24 AM / IP Logged
Done it on the Highlander, it's not hard to figure out. Look for shielded wires going to the back of the display...
Mike M2
Tech Manager
CS Dealer Services
mangolango
Member - Posts: 11
Posted: May 28, 2011 at 5:06 PM / IP Logged
Thanks Mike! how you find the wire? You use meter to fine it?
Mike M2
Posted: May 30, 2011 at 6:53 PM / IP Logged
No, simply look at the back of the display. Open the harness up a little and look for the only wire there that is shielded like an RCA jack wire is.
Mike M2
Tech Manager
CS Dealer Services
mangolango
Member - Posts: 11
Posted: June 11, 2011 at 7:35 PM / IP Logged
My sienna don't have the wire that you told me?? Is that 2 wires? I screw up the whole thing! My Dash and the Multi information display is not working now have to go toyota to fix it :( All the indicator light and the gauge is not working :(
mangolango
Member - Posts: 11
Posted: June 20, 2011 at 5:24 PM / IP Logged
I found a cable behind the Screen that has 4 wire red, black, white with brown dot and orange that look like RCA wire. Which one should I tap into the Video source?
