2006 fusion headrest wiring
shadow818
Member - Posts: 26
Posted: October 13, 2013 at 1:15 PM / IP Logged
Ok I have 2006 fusion that I bought headrest monitors for I'm kind of stuck between how to wire them to give them 12v I'm thinking of tapping into the cigarette lighter fuse at the fuse panel or radio fuse or straight from the battery what do you recommend is the best way to wire it m also it has side airbags so I'm guessing I should be extra careful when running the wires threw . Any info woukd help thanks
Platinum - Posts: 13,725
Posted: October 13, 2013 at 4:48 PM / IP Logged
I would not connect it to constant power. If the cig lighter turns off with the key, use that.
I really do not see a problem with the side airbags, all of your wiring SHOULD go under the door sill plate at the bottom of the door.
shadow818
Member - Posts: 26
Posted: October 13, 2013 at 4:52 PM / IP Logged
Well I was thinking of putting a switch to turn them on and off
Posted: October 13, 2013 at 5:56 PM / IP Logged
Forget to turn the switch off one night, then re-read my earlier post.
