DVD Power question?
Nocturnal
Copper - Posts: 85
Posted: August 23, 2003 at 10:27 AM / IP Logged
Hey guys.  I have a Phoenix Digital Mobile DVD player that has the cigarette lighter 12Volt input.  It also has a 12volt output that I assume is for the video.
My question is, does anyone foresee a problem with splitting this 12Volt output between the monitor and the wireless FM modulator?  The FM modulator can use 12Volt or batteries.  I'd rather use the hardwired power of course.
Any help would be hot.
brianh
Silver - Posts: 518
Posted: August 23, 2003 at 7:11 PM / IP Logged
I would check the fuse size on the output wire. If it is one amp I wouldnt use it. But if it was 3 or a 5 amp fuse you should be fine.
Brian
owner/installer
Sight & Sound Car Stereo
"all electronic equipment runs off of smoke, once you let it out, it stops working"
NextelOnline123
Copper - Posts: 64
Posted: August 23, 2003 at 9:44 PM / IP Logged
if it is a 1 amp use a relay if you want to dvd player to control the power
Nocturnal
Copper - Posts: 85
Posted: August 24, 2003 at 5:21 AM / IP Logged
The fuse is of the 3 amp variety.
Thanks a bunch guys...
Friday, April 24, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
