Headrest monitor power problem
blaziantiger
Posted: March 26, 2004 at 3:35 PM / IP Logged
Ok, before I get into the problem, let me tell you what I'm working with
1999 Ford Contour with stock battery, and two 5.6 inch Movies2Go monitors, 12 gauge power and ground wire
So, the way I have the TVs powered is there is one power wire for each TV coming directly from the battery. The wire then is fused with a 3A in-line fuse, then it goes to an interruptor switch (a blue glow switch from Autozone) then to the TV. Each TV as well as each switch is grounded on a single wire back to the battery's negative post. When the car is on ACC and the radio is on, I can turn both switches to ON and press power on both TVs, and they will power up. However, when I start the car up, the switches stay glowing but one of the TVs goes out as if it's not getting any power. Any idea why? Thanks for the help, if you need more details let me know
Moderator - Posts: 12,488
Posted: March 26, 2004 at 4:04 PM / IP Logged
Try switching the switches around and if the problem flips over when you switch the switches, then you have a faulty switch. Post your results.
blaziantiger
Posted: March 27, 2004 at 12:25 AM / IP Logged
See, I know it isnt the switch because I had the same problem before when I had both TVs running off of one switch. I also dont think it could be the switch, because how could the switch not work ONLY when the car is running?
Another detail: when the car is running and the faulty monitor is off, if I turn on an accessory like the headlights or interior lights, the screen flickers a couple of times like its getting a little power jolt. But, it still doesnt come on
Sound Pressure
Silver - Posts: 711
Posted: March 27, 2004 at 4:33 AM / IP Logged
Check your positive(12 volt) connection with a dmm and make sure that you are getting 12 volts while the car is running on those switches when they are switched on.
Sound Pressure
Posted: March 27, 2004 at 10:29 AM / IP Logged
Also, check to make sure that you do not have a cold solder inside the unit where the power, ground and IGN wires go into the back of the unit.
Thursday, January 8, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
