kenwood kvt 715
monkeyarms13
Posted: July 01, 2004 at 8:17 AM / IP Logged
Hi, i have the kenwood kvt 715 7'' touch screen dvd/cd unit. i've installed a few in-dash tv's in my time, and several cd players. but i can't figure this one out. It is on and everything seemed to be working fine. the radio works fine, all controls are working. how ever when i put a cd in , it shows that the disc is playing, but no sound comes out. also when i put a dvd in, it will play teh dvd, u can see the picture, but no sound. i'm completely puzzled! any help would be greatly appreciated. thanks
Josh
kenmci
Copper - Posts: 161
Posted: July 02, 2004 at 2:40 AM / IP Logged
more than likely your car has a factory amped system or you have an aftermarket amplified system.  Try switching the power ant wire behind the deck (blue), with the remote turn on wire (blue/white) and see if that makes a difference, if not then you may have a bad unit.  Just what I would try.  If you want to pm me with the car info, i'll see if there is anything else i can help with.
monkeyarms13
Posted: July 02, 2004 at 8:13 AM / IP Logged
yea it has a factory amp, i never even thought about that! it's a 97 Ford Probe base model, factory amp and sub. so just switch the power ant wire and remote wire and that should fix it, if that's the problem? thanks alot!
Josh
Friday, February 6, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
