AVIC-N1 GPS antenna installation.
Heckler
Member - Posts: 6
Posted: October 20, 2004 at 11:13 PM / IP Logged
In the installation manual Pioneer makes it a point to make sure you use the metal plate thing if you install the gps antenna inside the vehicle on the dash. Has anyone tried to install it without it? I really cant see how it would make a difference???
Heckler
Member - Posts: 6
Posted: October 22, 2004 at 3:26 PM / IP Logged
Can anyone help?
NowYaKnow
Gold - Posts: 1,217
Posted: October 22, 2004 at 6:03 PM / IP Logged
While it will work with or without without the metal plate, it is "supposed" to work better with the metal plate. The metal acts as a ground plane and helps to reflect (deflect?) the signals. Also the metal plate usually has double sided tape on one side which makes it easy to stick the plate to the dash then the antenna (which is usually magnetic) sticks right to the plate.
If you don't like the look of the metal plate, try it without it. If it doesn't work too well, try it with it. Regardless it definately isn't REQUIRED for the antenna to work.
Mike
Heckler
Member - Posts: 6
Posted: October 22, 2004 at 6:16 PM / IP Logged
Thanks Mike, I guess trying it without first makes sense... "smack on forehead"AVIC-N1 GPS antenna installation. -- posted image.
ODLeon
Copper - Posts: 57
Posted: October 25, 2004 at 1:50 AM / IP Logged
the metal plate gives you better reception, i tryed without and with, and def. better reception with. and it gives the ant. a place stick to if you have a plastic dash.
