navigation in 96 accord
mazdasquash1
Posted: December 30, 2004 at 6:31 PM / IP Logged
i'm fairley new at this how do u hook up the reverse light circuit and were is it located thanks
auex
Platinum - Posts: 5,041
Posted: December 30, 2004 at 8:16 PM / IP Logged
Well, in a honda it is probably running down the driver's kickpanel. As for the wire color, don't know it and can't find it. If you go to the trunk and look at the wires going into the brake light assembly, you can find the color. Just test for the wire that shows +12V in reverse, and ground at all other times. That will be the color and then just look for the same color in the driver's kickpanel.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
mazdasquash1
Posted: December 30, 2004 at 8:24 PM / IP Logged
thanks alot man
auex
Posted: December 30, 2004 at 9:29 PM / IP Logged
Found it
Reverse Light GREEN/ black   +   driver kick, harness to rear
