91 Mustang Tv Install
jnuts247
Member - Posts: 31
Posted: January 31, 2005 at 1:51 PM / IP Logged
I am installing a new tv in my 1991 Mustang but i need help with Wiring Diagram, I Need The Ignition Wire, So the tv will open when the car starts, thanks for the help
dr_bsmax1
Posted: January 31, 2005 at 7:59 PM / IP Logged
Hay,
Try to do this. Go to the RED / Light Green wire on the Ignition Switch Harness and splice your positive cable to this wire. It will always open everytime you turn your ignition. CAUTION: if you do this, it will wear down the motor on the headunit. It will work. If you just want to keep constant power to your headunit, then connect your power wire to your cigeratte lighter power wire. You will have to turn it on and off mainly, but that way you can use it even if you do not have the car on.
