Factory DVD Combo Ford Explorer
gforceman
Member - Posts: 14
Posted: March 12, 2005 at 7:33 PM / IP Logged
 does anyone have the wiring pinouts from the 20 pin connector - thank you  ,  factory DVD combo ford explorer
gforceman
Member - Posts: 14
Posted: March 13, 2005 at 5:55 PM / IP Logged
ok i hope this helps ---  sorry
I have an overhead factory DVD player that I am trying to install in my Explorer 02 XLT w/ sunroof.  I do not have the higher level radio or the body harnesses to connect it.  Can anyone provide pinout information so that I can build my own harness.
I do have the harness that goes from the player to the connector.
I have determined the following pinouts so far DVD harness to Body connector.
Pin 1 WHITE/ yellow +12 ?
Pin 2 not used
pin 3 black - ground ?
Pin 4 not used
Pin 5 not used
Pin 6 not used
Pin 7 not used
Pin 8 not used
Pin 9 not used
Pin 10 Red=?     audio out ?
Pin 11 White=?   audio out ?
Pin 12 Orange=?  audio out ?
Pin 13 Yellow=?  audio out ?
Pin 14 Black Shielded=?  Audio Grnd
Pin 15 ORANGE / black
Pin 16 BLACK/ blue
pin 17 not used
pin 18 lt blue/orange
pin 19 brown
pin 20 GREEN/ black
I have applied power to the player.  It will accept a DVD and spin it for 10 sec.  However the eject button does work other buttons and LCD do not function.
Any help would be appreciated
gforceman
Member - Posts: 14
Posted: March 14, 2005 at 10:54 PM / IP Logged
any takers ?
Victorbmw
Member - Posts: 15
Posted: March 19, 2005 at 11:16 PM / IP Logged
You are in luck!!!!!!!
I have installed the system in my Explorer EB 02.
First you mention you dont have the High end Radio, that is not good since the RADIO PROVIDES 2 signals to the rear entertainment called DATA BUS Protocol 1 and 2 and with out this the system will not work. I will have a radio available later on this moth for around 250.00 plus shipping. Also I will provive you with all the pin outs from the radio and the system. Let me know
Factory DVD Combo Ford Explorer -- posted image. victorbmw
gforceman
Member - Posts: 14
Posted: March 19, 2005 at 11:20 PM / IP Logged
thx alot for the reply - for now can you send me the pinouts for the connector ill get back to u about the radio  thanks alot
Victorbmw
Member - Posts: 15
Posted: March 19, 2005 at 11:39 PM / IP Logged
pin 1  fused battery
      3  ground
      10 left audio out +
       11 left audio out -
       12  right audio  +
        13 right audio -
        14  drain wire shield
         15   pulse with dimmer fused lead
          16  electronic module logic ground
          18  j1708 bus/audio corporate protocol A
           19 j1708                                               B
           20 audio system ASYSON on
all others not use
hope this helps.
gforceman
Member - Posts: 14
Posted: March 19, 2005 at 11:48 PM / IP Logged
is there ANYWAY to bypass the bus line ????
Victorbmw
Member - Posts: 15
Posted: March 20, 2005 at 12:03 AM / IP Logged
Check out Installer.com they have Data Bus Adapters. You might need to call them to ask for one compatable with ford.
The out put from the TV is low signal you might need to add a line balancer High /low in order to add an AMP to hear anything.
