Posted: April 29, 2005 at 12:08 PM / IP Logged
Posted: April 29, 2005 at 2:50 PM / IP Logged
Posted: April 29, 2005 at 4:41 PM / IP Logged
Posted: May 02, 2005 at 10:19 AM / IP Logged
Posted: May 02, 2005 at 3:56 PM / IP Logged
Posted: May 02, 2005 at 4:25 PM / IP Logged
Friday, May 1, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
Pin:
A1: BROWN / White - MIL Control
A2: Not Used
A3: BLACK/ White - Low Washer Fluid Control
A4: Dark GREEN / WHITE - Vehicle Speed Signal
A5: White - Engine Speed Signal (Tach)
A6: Gray - IPC Class 2 Serial Data
A7: Not Used
Sorry about that should've been more descriptive.. The wire you want is in pin A4. I've listed some of the other wires around it to help you pick it out. Hope it helps,
Mike
